F-Type Dead as a Doornail
Old Jul 30, 2020 | 03:39 PM
Kilowatt3's Avatar
Default F-Type Dead as a Doornail
Greetings, All. LTNS!
I went out this morning and found my 2016 F-Type stone cold dead. Won't start, no accessories working, and it won't talk to the OBDC.
Rear hatch won't open, Glove compartment won't open. Door locks don't work - I found the car unlocked, but I think it unlocked itself. Pretty sure I'd left it locked. Tried using the remote, and the Android App - no luck with either.
The car gave NO indication of any problems in advance. I was driving it yesterday, and everything was fine right up to when I parked it. Before I tear into it, or call the shop, I just wanted to check on here in case there's a quick fix or diagnostic anyone can suggest. I did check the fuse (F17) for the Engine Management System and it looked OK.
HELP! and TIA,
Jim
Old Jul 30, 2020 | 03:48 PM
Noshame's Avatar
Sounds like a new battery is in order.
Old Jul 30, 2020 | 04:02 PM
lpf4's Avatar
If it's unlocked, pop the hood and check the voltage at the jump start posts if you can't get into the trunk (not sure if there's a key slot in the trunk for the emergency key?). If you get 0 volts there, or 12+ volts, something other than just the battery is likely going on, but if it's low volts, battery is most likely the culprit. If that's the case I'd also try jump-starting it then checking voltage to make sure the alternator is putting out 12+v too.
Old Jul 30, 2020 | 04:06 PM
scm's Avatar
scm
Originally Posted by lpf4
... not sure if there's a key slot in the trunk for the emergency key? ...
AFAIK, there's no manual way into the boot - electricity needed.
Old Jul 30, 2020 | 06:01 PM
Unhingd's Avatar
Unless you’re driving around with a midget in the trunk to pull the manual release.
Apply power to the electrical terminals in the engine compartment to see if you can open the rear hatch.
Old Jul 30, 2020 | 06:04 PM
OzXFR's Avatar
Reads like you are able to open the door and get into the car, in which case you can open the hood and access the charging points.
Then hook up a decently powerful battery maintainer (not a charger as they can damage the electrics) to those points and leave it going overnight.
This should "repair" the battery enough to at least open the hatch and maybe start the car, and if you are really lucky it might even completely "fix" the battery, although a completely drained battery usually doesn't fully recover.
Old Jul 30, 2020 | 06:18 PM
scm's Avatar
scm
Originally Posted by OzXFR
... hook up a decently powerful battery maintainer (not a charger as they can damage the electrics) to those points and leave it going overnight.
I believe the CTEK won't actually charge if the battery is completely flat. Other maintainers may, or may not, exhibit the same behaviour.
Old Jul 30, 2020 | 06:19 PM
EdG's Avatar
EdG
Agree. When my battery died, I used battery booster on the terminals in engine bay to turn on electronics and that allowed me to open back to access battery. If you are going to try to jump, do it from the battery. I tried to do it from the front jump points but it didn't work.
Not sure why it would have drained overnight unless you accidentally left something on. If it was an old battery it will die fast. Hopefully it is the battery. Cheapest fix. Good luck.
Old Jul 31, 2020 | 05:35 AM
scm's Avatar
scm
That's interesting as the underhood points are the Jaguar recommended way to do it. Probably because it's easier to open the hood with a dead battery.
Old Aug 1, 2020 | 04:36 PM
Shimmy1122's Avatar
By any chance did you plug in a obd2 code reader before hand? I did this with mine before and had the same issue. Something about the power modules having to be reset after plugging in a code reader. After recharging the battery I disconnected it for about 10 minutes and reconnected it. No problems since.
Old Aug 2, 2020 | 08:27 AM
Alasdair 63's Avatar
I had the same issue, I jump started the car with the terminal under the hood and went for a 45 minute drive and put the cetek on when I got back home. As scm said
the cetek won’t charge a flat battery , that was six months ago never had a problem since
Old Aug 3, 2020 | 06:01 PM
EdG's Avatar
EdG
I was surprised when I figured out the engine leads didn't work as well as the battery because of what I read from Jaguar. That is why I am letting you know. The guy who came to tow my car said he has seen the same issue with other brands so it seems like it wasn't Jag specific. He suggested we try jumping from the battery and it worked. Let me drive to the dealer (still under warranty).
green_hornet
Feb 21, 2018 01:49 PM
Roadan
Jul 31, 2016 08:45 PM
polarisnavyxj
Jun 7, 2016 05:11 PM
markbridge
Apr 8, 2016 10:53 PM
amcdonal86
Mar 19, 2013 09:50 PM
