F Type Engine Fire
Old Dec 27, 2018 | 06:52 PM
mcsahib's Avatar
Default F Type Engine Fire
My 17' F Type 've 20k miles, the engine threw the rod, and caused a vehicle fire. Jaguar USA denied warranty claim and blamed the engine failure on under carriage impact. What can I do?
Old Dec 27, 2018 | 07:29 PM
SinF's Avatar
First, there is difference between Jaguar USA and a dealer. Do not assume that dealer you took the car speaks on behalf of JLR. Second, do not assume that dealer telling the truth about how it failed or that they even talked to Jaguar USA about your case - they might not want the hassle of swapping the engine at JLR rates and blowing you off.
Is there any signs of impact as this dealer claims? Did you feel impact shortly prior to engine failure? If yes to both - talk to your insurance, this isn't any different from running your car into the pole. They may write the car off, but if not, insist new and not used engine. If there are no signs and you didn't feel the impact - talk to actual Jaguar USA and they will put pressure on dealer to stop BSing you and do the job. They might also tell you to take it to a different shop.
Connecting rod could puncture a hole in the block, however it won't fail without reason. If you tuned your engine or neglected to change oil... well, you are in a bad situation. Even if there is a hole now doesn't mean that it was caused externally. Take your car to another shop to offer you a second opinion. Ideally an engine shop and not just a mechanic. You might be able to convince JLR with that information.
Last but not least - this is first failure of this kind we heard on this forum. This is third engine failure reported so far - other two were due to oil loss. My wild guess is that your engine also threw a rod due to lack of oil, not external impact.
Old Dec 27, 2018 | 07:36 PM
JIMLIGHTA's Avatar
Banned
If the dealer denies the claim due to a collision, it' s an easy insurance claim.
Old Dec 27, 2018 | 07:51 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Contact the rep on this forum , you'll find it below under "Brand Review" 2nd thread topic under the title.
Good luck
Old Dec 27, 2018 | 08:15 PM
mcsahib's Avatar
Default engine fire
It is Jaguar USA that denied the claim.
Old Dec 27, 2018 | 08:21 PM
mcsahib's Avatar
They claimed the damage is caused by under carriage impact. But from the picture it is pretty clear that the rod punched a hole to the engine block and everything underneath the hole (steering rack, sub frame) are undamaged and the damage is even between both wheels!!
Old Dec 28, 2018 | 12:50 AM
sov211's Avatar
Well, regardless of what the evidence tells you, if JLR will put in writing that the damage and resultant fire were caused by hitting something on the road, you then have documentation for an insurance claim. If the insurance company disputes this, then you leave it up to JLR and the insurance company to sort it out...if you have documented oil changes, you are the innocent party. One of the other two must shoulder the cost.
Old Dec 28, 2018 | 01:42 AM
Jaggyx's Avatar
Bingo. Sorry to hear OP.
Old Dec 28, 2018 | 12:58 PM
Unhingd's Avatar
That looks like it was a catastrophic event not only destroying the engine, but also the suspension undercarriage and perhaps also the frame. With the fire damage, that car may be a total loss.
Old Dec 28, 2018 | 06:22 PM
FType17's Avatar
Without having all the facts... Please allow me to suggest this.
You hit the front undercarriage hard (like the curb of a sidewalk), hard enough to damage the suspensions and flex the frame enough to stress the engine mounts (and lower bock). AT HIGH RPM. Rod snaps at the crankshaft and pokes out of the block. Close enough to the cat converter with oil going all over the place. That's a collision and an insurance issue no matter what.
The warranty is based on normal use of the car, not collision.... I assume that the fire department and Police were at the scene, there is a report so the insurance should have all they need.
Old Dec 29, 2018 | 05:39 PM
SS4PK's Avatar
I too am not sure the OP is telling the whole story
Old Dec 31, 2018 | 10:13 AM
WJV's Avatar
WJV
Agree. OP probably riding around with no insurance trying to blame JLR to force a warranty claim.
Old Dec 31, 2018 | 11:41 AM
sov211's Avatar
My repeated question (in various threads): where is the OP? How and why do they simply go silent or disappear like a sock in the dryer? Or is it simple discourtesy?
Old Dec 31, 2018 | 12:19 PM
scm's Avatar
scm
... where is the OP? How and why do they simply go silent or disappear like a sock in the dryer? Or is it simple discourtesy?
It's only been three days since his last post - maybe he's in a dark room getting over Christmas, or the damage to his engine ....
Old Dec 31, 2018 | 01:23 PM
Unhingd's Avatar
asynchronous communication?
XJ12C_Driver
Aug 31, 2016 12:23 PM
RagJag
Jul 17, 2012 01:05 PM
latte8890
Jun 16, 2011 11:46 AM
Dinger
Feb 1, 2010 11:13 AM
