F type front number plate
Old Nov 8, 2017 | 04:15 PM
powerhouse's Avatar
Default F type front number plate
Can someone tell me the measurement of the cross bar part that i have arrowed in the picture, want to fit a small plate, the second pic is the kind of effect i'm after, i purchasing a car but want the plate ready to go, forgot to measure it at the dealers
Old Nov 8, 2017 | 05:22 PM
OzXFR's Avatar
The flat part before it starts to curve, pretty much per the stick-on plate in your second pic, measures 2.75" or 7 cm.
Old Nov 8, 2017 | 05:45 PM
powerhouse's Avatar
Thanks, don't want a big plate like below, as the plate will probably be flat , what size would just a nice size just to cover the top and bottom of the cross bar a bit as yellow box.
Old Nov 8, 2017 | 08:20 PM
DPelletier's Avatar
The best look for an F type and licence plate IMO;
Old Nov 8, 2017 | 09:22 PM
Unhingd's Avatar
+1.
Old Nov 8, 2017 | 09:42 PM
Burt Gummer's Avatar
Sto-N-show or no go Joe.
Plate on bumper? Tacky.
Old Nov 8, 2017 | 09:49 PM
Andy2017's Avatar
+1
Old Nov 9, 2017 | 01:25 AM
Misujerr's Avatar
Aw, c'mon, don't leave the guy hanging!
https://www.summitracing.com/search/brand/sto-n-sho
Old Nov 9, 2017 | 01:48 AM
OzXFR's Avatar
Yep, I would like a Sto'N'Sho as well, but absolutely no go in Nanny State South Australia.
Here, by law, the bottom edge of the front numberplate must be at least 300 mm (about 1 foot) off the ground, and the Sto'N'Sho is waaaay lower than that.
Old Nov 9, 2017 | 01:56 AM
BruceTheQuail's Avatar
I have black background slimline plates in black holders, you pretty much cant even see them except for the writing. The plates are 10cm high, so they come up about 5mm over the top of the bar and 25mm below.
Old Nov 9, 2017 | 07:33 AM
911Königin's Avatar
My state requires front plates - am going to try and run without them as long as I can. May have to try that Sto - N - Show.
Old Nov 9, 2017 | 09:34 AM
Biofreak's Avatar
I'll go take some measurements for you in a bit if this is what you want to do?
Old Nov 9, 2017 | 12:57 PM
Kjamo's Avatar
State law in WA requires a front plate. I chose not to display one. I've been pulled over twice in last 2 1/2 years. One ticket for 10 mph over and one let off. The missing plate was never mentioned.
Old Nov 9, 2017 | 02:26 PM
15FTypeR's Avatar
My car came from california and spent 2 years and 15,000 miles there with no front plate on it. I do not know how many fines were paid by the previous owner if any.
In my current state I use a sto-n-sho purchased directly from STO N SHO Removable Quick-Release Front License Plate Bracket
Very fast shipping, 100% satisfied with the quality.
Old Nov 9, 2017 | 09:20 PM
R1nZX's Avatar
Good to know. I've been running no front plate here in WA for the last 5 years but hadn't been pulled over yet. So far so good...
Old Nov 12, 2017 | 07:01 AM
powerhouse's Avatar
Yes thanks that's exacting it, might go for a vinyl stick on or like your picture, measurements would be great, might fit lower down either
Old Nov 13, 2017 | 04:23 AM
Meister_Kajo's Avatar
Use an aluminum sheet and bend it at a 90 degree angle. You can then attach this under the front spoiler with tape and a screw.
The aluminum sheet you can perfectly cut to your length of the plate and paint.
Old Nov 16, 2017 | 05:18 PM
powerhouse's Avatar
Ok Bruce, i'm putting on no number plate surround, just fitting the smaller rectangular plate with double sided tape to the cross bar, So as i said i just want it 5mm above and below the bar, so what size would that be. You say yours are 10cm and 25mm, the cross bar must be small
Old Nov 16, 2017 | 06:07 PM
DJS's Avatar
DJS
The face of the crossbar is very close to 3 inches tall.
Old Nov 16, 2017 | 11:26 PM
Yes the front face is just on 70mm but it then slopes upward toward the grille and gains what looks to be another 15mm or so. So even if the plate sits proud of the crossbar at the front, it isnt covering the grille.
