F-Type Non-marring phone mount (Beta)
Old Feb 28, 2021 | 12:49 AM
schuss's Avatar
Default F-Type Non-marring phone mount (Beta)
I would never drill holes or use sticky anything on dash, that hurts my heart. I'm also not into mounting things on vents that could break the vents or be wobbly. So I solved the problem another way. This is all kind of temporary until I'm sure it's working, but so far with a week of driving around it's going pretty well. Still BETA status though, early prototype.
For now I am just using some velcro wire straps, but since that's working I'm making a permanent one out of nylon webbing and heavier velcro.
I ordered this auto-clamping phone mount with wireless charging built in ($28 USD):
https://smile.amazon.com/gp/product/B089QH1DWL/
A good quality USB plug for the cig/power port ($15 USD):
https://smile.amazon.com/gp/product/B088CXRSQL/
And a short (6") micro USB power cable for the phone mount ($6 USD):
https://smile.amazon.com/gp/product/B013G4EAEI/
Then I designed and printed this bracket to sit on the console spar. The ball joint on it fits into this phone mount's ball socket.
Still looks like a beta with this rough print and the temporary velcro. But it doesn't leave any marks on the leather at all, can be removed easily with one velcro strap, and faces me well enough in the driver seat to unlock my phone with my face.
This phone mount is pretty great and I think fits the Jag very well, too, with its automatic arms that grip the phone and the elegant little motorized release when you touch the silver side buttons. I think with a nice plastic part and the right velcro strap, it could be pretty stylish.
Working on the velcro strap now, will update when I have something nice!
Designed for LHD, but if anyone's interested I could flip the design for RHD cars easily enough.
Old Feb 28, 2021 | 07:16 AM
2004XJ8's Avatar
Nice work I like it!
Old Feb 28, 2021 | 07:20 AM
NJ68's Avatar
Yes! ... Nice solution.. IMO best I've seen...
Old Feb 28, 2021 | 10:55 AM
datriani's Avatar
Nice work. Looks great and I really like the mount you designed. Must more professional than what I bought off etsy. Would you consider creating one for me for a price?
Incase others have an iPhone 12 with the Magsafe charging/mounting capability, this is what I threw into my F type.
6" USB-C Cable
Amazon Amazon
Dual (USB and USB-C) cigarette lighter plug
Amazon Amazon
MagSafe Charger mount
Amazon Amazon
Old Feb 28, 2021 | 11:51 AM
cpq100's Avatar
I recently ordered a dash pad mat which is meant to hold your phone. I do not plan on using it for my phone though. My suction cup mounted radar detector has a bad habit of falling off the windshield. I don't want it marking up the dash, so this pad is going under it. I could not resist getting this since it has the Jaguar logo on it. I ordered from Aliexpress. I will post a follow-up once it arrives.
https://www.aliexpress.com/item/1005...archweb201603_
The same pad is available on Amazon with a set of rubber cup holder inserts. I already had the inserts so I order off Aliexpress.
Amazon Amazon
Old Mar 1, 2021 | 11:10 AM
schuss's Avatar
6" USB-C Cable
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
What's the backside of that mount look like? Could possibly work the same way.
Old Mar 3, 2021 | 06:01 PM
datriani's Avatar
Yes, it's basically the same ball joint type of mount but I like the OP part as it looks more substantial and professional.
Old Mar 3, 2021 | 08:19 PM
Craaaazzy's Avatar
That’s pretty nice. May be interested if you start making them depending on price.
Old Mar 4, 2021 | 10:13 AM
Damon Parker's Avatar
I purchased the Pro Clip phone holder and really like it. I used the console mount with the magnetic holder. I found that if I placed the metal plate towards the bottom of the phone case, it does not interfere with the wireless charging in my desktop cradle.
Console Mount - ProClip Console Mount:
https://www.proclipusa.com/vehicle/d...ar-f-type/2017
Phone Holder for Iphone 11:
https://www.proclipusa.com/device/ph...pple-iphone-11
Old Mar 6, 2021 | 07:07 AM
Unhingd's Avatar
I have found the Infinniapps magnetic/suction mount to work perfectly. No marring/ very stable.
Old Mar 10, 2021 | 01:18 PM
Jag Bass's Avatar
Cant you just make it wrap over the top and do away with the velcro? Kind of like the rendering below.
Old Mar 10, 2021 | 02:00 PM
schuss's Avatar
I tried that at first but in order to not slide down the rail it needs to be really tight, and I didn't want to leave marks in the leather. Maybe if I could put a felt lining on it or something?
Old Mar 10, 2021 | 02:42 PM
Jag Bass's Avatar
Place a piece silicone sheet on the inside of the clip. And just before you put it in place, mist it with isopropyl alcohol which should make the surface slippery and easy to pull over. Once in place and the Alcohol evaporates the silicone should keep it from sliding.
You could also try nano gel tape says it will not leave a residue if removed.
Old Mar 10, 2021 | 04:00 PM
HermanWiegman's Avatar
Great ideas being shared on this important feature.
I purchased a velcro strap secured mount with magnetic base (which required me to install a steel sheet in my cell phone case.
Cell Phone Mount with velcro (Etsy purchase)
Old Mar 11, 2021 | 11:47 AM
Craaaazzy's Avatar
really like the placement of this mount but does the plate rest on the shifter surround? how far down does it slide into the center console section?
Originally Posted by Damon Parker
Old Jun 11, 2021 | 04:30 PM
skizot's Avatar
Location for mine, 3D printed and leather wrapped.
Old Aug 2, 2025 | 03:17 PM
MCMike37's Avatar
For the longest time I was just using a suction cup mount just below the center cents. Finally got around to doing it right. Lots of test fitting and shaping but I'm happy with the way it turned out.
It blocks a couple of buttons I have never used so no loss.
Old Aug 3, 2025 | 05:12 AM
J444G's Avatar
Wow, that is probably the first "proper" solution I love. F-type is probably the most non-compatible car to put your phone ever!
To add something,
I am using this mount I am using this mount
I would rate it 3/5. It holds surprisingly well, but it rattles a lot. I have tried to fix it, but it is one part that cannot be fixed so it just have to be a bit noisy on rough roads and bumps.
Old Aug 3, 2025 | 05:56 AM
Jag Bass's Avatar
I have gone to this magsafe mount for all if my vehicles and switched to mag safecase for my android that hold solid as a rock. Solid aluminum construction and they articulates in everyway imaginable, very inexpensive. Best phone mount I have ever used.
https://a.co/d/7XY35Ix
Old Aug 3, 2025 | 07:39 AM
Robtrt8's Avatar
Basically a Pro Fit type mount. I like it.
I’m still rockin a heavily modified ProClip base with the new-ish Scocshe Qi2 MagicMount Charge.
