F-type r AWD died engine
Old Feb 13, 2019 | 10:35 AM
eeeeek's Avatar
Originally Posted by mohammed m
no warranty
but what do u think happen to engine
What I think happened is a licensed mechanic told you not to drive it and you drove it anyway. Then, you added WAY TOO MUCH OIL and the engine basically whipped the oil up into a frothy mess. By adding more oil, your car had less usable oil, and your engine is now a boat anchor. A quart too much oil can be much worse than a quart too little oil.
Old Feb 14, 2019 | 02:45 AM
mohammed m's Avatar
Again sad news
dealer and jaguar told me the engine is gone forever cuz of oil and i need to change the engine.
no warrenty 😢
any good website to buy ftype r 2016 awd ?
Old Feb 14, 2019 | 03:09 AM
Unhingd's Avatar
Again sad news
no warrenty 😢
Easy come, easy go? Since you already have the car, it will be less expensive to replace the engine than buy another car. You can source an engine at discount in the UK: Land Rover Parts and Jaguar Spares | Britcar UK Ltd. They will ship to Dubai.
Old Feb 14, 2019 | 05:05 AM
Nati's Avatar
Maybe stick with Uber
Old Feb 14, 2019 | 06:55 AM
Itismejoshy's Avatar
iv seen short-blocks on fleebay for 5-8k but your gambling unless you rebuild it 100%. How about making an insurance claim?? again sorry to hear this.
Old Feb 14, 2019 | 11:19 AM
scm's Avatar
scm
If an insurance company hears about adding the oil and driving against dealer advice you can bet what they'll say!
Old Feb 14, 2019 | 01:54 PM
Unhingd's Avatar
Josh, how would a non-collision, non-vandalism, non-act-of-god event qualify for insurance coverage?
Old Feb 14, 2019 | 02:07 PM
  #28
Unhingd's Avatar
Brand new short block: https://www.brit-car.co.uk/search.ph...t=&xPerPage=10
5800 pounds sterling in the UK
$8800 in the US
Old Feb 15, 2019 | 02:38 AM
Queen and Country's Avatar
In Dubai no less...lol
Old Feb 15, 2019 | 04:21 AM
  #30
I dont think the cause of failure was the timing chain.
When the timing chain jumps, the restricted performance light comes on, power drops and you can drive home. Several have done it.
And you dont get a puddle of oil under the car.
The excess oil caused the failure in addition to whatever else was wrong in the first place.
And the noise occurring under acceleration tells me it was cam actuator.
Old Feb 15, 2019 | 06:56 AM
  #31
$8800 in the US
This is amazing, never figured to look there, good find!
Old Feb 15, 2019 | 02:28 PM
  #32
Unhingd's Avatar
JaguarLandRoverRenoParts has it here in the US FOR $8800
Old Feb 19, 2019 | 12:48 AM
  #33
mohammed m's Avatar
Default F-type r AWD died engine
hi guys
I need to change my short enigine block cuz its damaged
which model fit my jaguar ftype r awd 2016
for ex: xk xj range rover
Old Feb 19, 2019 | 01:53 AM
  #34
Jst2gtby's Avatar
Care to share what happened? 🤔
Old Feb 19, 2019 | 02:07 AM
  #35
OzXFR's Avatar
If it's just the short block then my understanding is that any AJ133 SC will work, so that covers RR, XKR, XFR, XJR and F-Type from 2009 to now.
Old Feb 19, 2019 | 02:43 AM
  #36
mohammed m's Avatar
dealer said i need AJ812891
im new in cars
they said there is 2 part in my engine
strip engine and shortblock engine(lower)
and i need to change it
Old Feb 19, 2019 | 06:51 AM
  #37
Nati's Avatar
see user's other thread. summary points: ignored mechanic's advice, overfilled with 2 liters of oil, destroyed engine via self immolation
Old Feb 19, 2019 | 07:17 AM
  #38
SinF's Avatar
yes the engine completely locked
You need entire engine (long block) instead of just short block. You shouldn't reuse old heads as failure sent metal chunks throughout your engine.
Here is what likely happened to your engine. You overfilled by a lot then pushed the car, at that point oil was hitting crank and got aerated (think whipped cream). This in turn starved crank bearings from lubrication and they overheated, spun (that was noise you were hearing) and then got welded by heat due to friction to block. That entire process sent mental through your engine gumming up hydraulic lifters, adjustable timing gear, damaging rings, valve seals, cams... sorry, it is all junk and no saving it.
Old Feb 19, 2019 | 07:45 AM
  #39
Unhingd's Avatar
Probably true, but I would chance reusing the heads after immersing them in a solvent bath. The same will have to be done with all the oil lines as well.
Mohammed, AJ812891 is the specific part number for the short block. AJ133 refers to the engine designation for V8s produced post-2008.
Old Feb 19, 2019 | 09:10 AM
  #40
SinF's Avatar
Would you still chance reusing if you were paying labor for someone else to do it?
The issue I see is variable cam timing and hydraulic lifters. You can't determine if they work correctly by inspection (at least I don't know how to simulate oil pressure and bench test it), and if you are paying for labor, trying old parts on could get very expensive.
