F-Type R Muffler Delete
Old Mar 25, 2018 | 06:49 PM
FType17's Avatar
Capristo also deletes the scavenging effect of cross-pipes...
Old Mar 25, 2018 | 07:42 PM
Chawumba's Avatar
Ah, but see on the lower pic, those lengths of pipes coming off at 90 degree angles, they look like some sort of drone cancelling (Hemholtz resonator) system. And on the VAP system, we can't see the cutaway, but there may be similar piping. Also, at least on my car model, even in loud mode, the valve does not fully open until a certain RPM.
My 2 cents, get one of these systems, so you know you are getting the good sounds and less of the bad. Engine drone is annoying as heck. I bet 9 out of 10 forum members would find the VAP system plenty loud enough in loud mode - at WOT it screams. The 10th probably wears nomex suits to work.
Old Mar 25, 2018 | 10:03 PM
Unhingd's Avatar
Originally Posted by JMichael_LA
Also I’ve seen a cutaway of the F-Type V6 exhaust and when the valves are open it’s pretty much also a straight pipe.
Not really straight through. Notice the perforations in the "straight through" pipe allowing pressure into the main body of the muffler. This has the effect of absorbing a significant amount of sound energy.
Old Mar 25, 2018 | 10:25 PM
OzXFR's Avatar
Yep, the whole design looks very complicated and must have taken thousands of hours of R&D. Odds on the same amount of complication and R&D for the V8 exhaust. Sometimes KISS is not the best way to go!
Old Mar 26, 2018 | 12:02 AM
zmoothg's Avatar
I did a muffler delete for a day, it was horrible. Worst idea ever. Sounded loud as f@#$. I am now running the 200-cell downpipes from VAP and the VAP Valvetronic exhaust and it's still freaking loud when the values are open (basically a straight pipe), but beautifully loud. I will get around to recording a clip of it soon, but its exotically loud, I can't imagine wanting louder.
Here is a clip I put together last year, but I think it would be better to do a clip of my car next to a stock F-Type R to really show the difference. Now need to find a stock F-Type R who wants to rev with me.
Old Mar 26, 2018 | 11:14 AM
FType17's Avatar
Technically it's a small mini muffler, not the whole main body of the muffler. With that said, it's probably packed with glass wool.
Old Mar 26, 2018 | 12:57 PM
Freedom8675's Avatar
Install Exhaust Cutouts. Makes it as loud as you want then back to stock with a push of a button
Old Mar 26, 2018 | 10:24 PM
  #28
zmoothg's Avatar
Clever setup.
Old Mar 27, 2018 | 04:39 PM
alphakinase's Avatar
Looking at those pics of the stock V8 setup...
Any ideas why the V8 lacks the center 2x2 muffler that comes on the V6 models? What is its function?
Old Mar 27, 2018 | 06:14 PM
  #30
OzXFR's Avatar
The V8 has a crossover pipe instead of a muffler/resonator.
A V6 without a central resonator nearly always drones like crazy, much worse than most V8s.
JLR would have tried the V6 and V8 exhausts in various configurations during R&D and probably found that the V6 needed a central resonator to reduce drone but the V8 didn't.
Also, a crossover pipe (or X pipe or H pipe) works on a V8 to improve exhaust gas flow due to the scavenging effect, but it doesn't work on a V6.
One reason why for some years now all high performance versions of the Jag 5.0 V8 have had a crossover pipe in the exhaust from the factory, eg XFR-S, XKR-S and F-Type R.
Old Mar 27, 2018 | 08:41 PM
  #31
Cambo's Avatar
Yeah I reckon JLR's exhaust R&D budget was a little bit bigger than most people realise. One of the reasons I left the stock rear muffler on my XKR and just changed the centre pipe as a "copy" of the XKR-S and F-Type V8, no drone for me!
Exactly.
The firing order of the V6 is even, fires on opposite banks, left, right, left, right, left, right, repeat.
The V8 firing order is uneven, left, right, left, left, right, left, right, right, repeat. The x-pipe helps to balance out the uneven exhaust pulses from each bank.
Old Mar 28, 2018 | 01:39 PM
  #32
FR500GT's Avatar
^^^ Some great input stated above.
I may try out the factory R X-Pipe on my V6. The R rear exhaust sounds perfect right now with no drone but I have the itch to try out the R X-Pipe. Who in CA wants to let me try out their factory X that they have laying around?
Old Mar 31, 2018 | 10:08 AM
  #33
Really interested to see how this goes. I've been thinking about doing an X-pipe as well.
Old Mar 31, 2018 | 05:32 PM
  #34
OzXFR's Avatar
I'm interested as well.
But from what I have read and based on advice from Cambo, putting an X-pipe on a V6 may change the sound but probably not improve it, and it's likely to have a negative effect on power, torque and performance. I hope to be proven wrong!
Old Jul 4, 2020 | 03:43 AM
  #35
xpunjabiball3rx's Avatar
Has anyone done a muffler delete to an F type R yet? Is it too loud?
Old Jul 4, 2020 | 09:08 AM
  #36
RGPV6S's Avatar
Check out post #25 of this thread.
Old Jul 4, 2020 | 03:24 PM
  #37
Burt Gummer's Avatar
The stock R exhaust is just about perfect for me, but yes, I agree with cutouts being always the best choice. Love them, always have. A buddy of mine has a Challenger 6.4, non-HC, w/ cutouts and damn. So brutal. Will love loud until the day I die. Reason why a Telsa would never interest me nor would a V6 Raptor truck. Fart can.
Old Jul 5, 2020 | 11:38 AM
  #38
zmoothg's Avatar
yes I did it and it sounded like garbage. Today I'm running stock setup with a velocity AP valvetronic and tune. Sounds delicious. I used to run the high-flow 200 cells downpipes until the cats gave out. That sounded mental but I liked it.
Old Jul 5, 2020 | 02:11 PM
  #39
StormtrooperFtype's Avatar
Originally Posted by sts-v
No problem. The reason it hasnt been done is because the muffler delete will sound like ****. Then again it might work well with the obnoxiously ugly red wheels. In my recommendation, Save it for the V6 mustangs.
Hi, no one asked for your opinion on his wheels. It's HIS money, not yours. I actually like the red wheels, its loud and has a good contrast. No need to be a dick to the guy he is asking for help.
Old Jul 5, 2020 | 02:35 PM
  #40
wadenelson's Avatar
Prior owner (PO) deleted the mufflers on my XKR.
ABSOLUTELY LOVE HOW IT SOUNDS!
As for the wheels..... you trying to pick up younger women? Roy Moore, zzzis you?
