F-Type remote key jam
Old May 5, 2019 | 05:49 AM
thewinelake's Avatar
Default F-Type remote key jam
My father in law has an F-Type and has been having terrible trouble locking and unlocking his car at home. I think there's some jamming signal in the area.
It's a very wealthy part of North Yorkshire, so it wouldn't surprise me if this was some kind of criminal activity, but it seems to be very persistent, and he hasn't had the car nicked yet!
The dealership seem unable to do anything about it, or even have much of a clue about the problem. Just wondering if there are any tips on ways to get around it. Maybe a Faraday cage around the garage?! Or maybe one can somehow change the frequency on which the key operates?
I'd like to go and visit with a scanner, but it's a long way.
Old May 5, 2019 | 06:14 AM
Welcome to the forums thewinelake,
I've moved your question from General Tech Help to F-Type forum. Members here with the same model will be able to comment on whether this is a known issue.
If you plan on staying with us rather than only making this a single visit, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old May 5, 2019 | 06:21 AM
DJS's Avatar
DJS
Wild, I was just reading this article on key fob jamming...
https://www.nytimes.com/2019/05/04/u...core-ios-share
Old May 5, 2019 | 06:37 AM
Yes - it's exactly something like that. Is there any way that he could get someone to go around with a scanner, I wonder - maybe I should join the North Yorkshire Radio HAM forum (assuming such a thing exists!) and ask there.
Old May 5, 2019 | 10:13 AM
Unhingd's Avatar
Or you could paper your entire garage in aluminum foil. There is also paint that can be used to thwart any kind of radio waves.
I line all my hats with aluminum foil to counteract alien mind control. I can just imagine someone in my neighborhood trying t turn my bulb on and off. lol
Old May 5, 2019 | 06:55 PM
stmcknig's Avatar
I actually recall reading an article somewhere that suggested leaving remote key fobs in a Faraday cage overnight that can be found in most kitchens - a microwave oven. Supposed to prevent the key fob from chirping back to scanner requests from tea leaves intent on making off with your pride and joy. Of course remember to take it out when you make your morning porridge otherwise you will be at least $400 poorer but still have your car. And a bowl of cold porridge.
Old May 6, 2019 | 01:22 AM
Default Some more developments
Mmmm. Just heard that the car has now been tested and the fault replicated at other locations. It has been escalated and we shall see if replacing lock/key might fix it.
Old May 6, 2019 | 03:09 AM
Tel's Avatar
Tel
Not a bad idea.
I trust that you have a healthy battery in the key fob.
In the UK 433Mhz band that the key fobs work on is a shared frequency with many higher power services/devices.
The higher power devices, such as hobby radio, commercial pagers etc do not transmit a constant carrier, ie they are not on hour after hour, but in short 'ish bursts.
Does he live close to a mast or comms tower in an elevated position?
It's a long shot and he would have to be relatively close for it to interrupt the signal.
P. S Faraday pouches or similar are not applicable in this case, only from stopping your fob from talking to the car.
Try 'Radioclassifieds' UK website for the best coverage in their general forum.
Old May 6, 2019 | 04:32 AM
Originally Posted by Tel
Not a bad idea.
Thanks, but I'm on hold now while I await the results of the latest "fix" ;-)
Old May 6, 2019 | 07:18 PM
Tel's Avatar
Tel
Yes, I see I replied just after you posted!
Good luck with the fix...
Old May 7, 2019 | 12:55 AM
CRS 123's Avatar
Check this out
https://www.thedrive.com/news/27829/...y-fobs-useless
alfred
E type ( XK-E )
Mar 28, 2015 07:23 PM
SteveSheldon
Apr 20, 2013 04:53 AM
SRL1990
Jul 26, 2010 01:57 PM
