F Type S 2014 Clunking from Centre consol
Old Feb 4, 2020 | 06:24 PM
6036Craig's Avatar
Question F Type S 2014 Clunking from Centre consol
Hi,
Just bought a new car. Well used but new to me. 2014 F Type Model S. Every now and again I hear a clunk noise from the centre console. Its spirradic and only hear it when pulling away or turning at low speeds. Its so intermitent so I cant record it really. - bugging me that much that i have the music on constantly just in case i hear it ha ha .
Any help much appreciated.
Old Feb 5, 2020 | 02:45 AM
Welcome to the forums 6036Craig,
I've moved your question from General Tech Help to F-Type forum. This is the place to post questions about your model.
Old Feb 5, 2020 | 05:32 AM
Unhingd's Avatar
It might be excessive lash in the differential gears. The noise will travel up the transmission tunnel. This is a known issue with F-Types.
Old Feb 5, 2020 | 09:10 AM
Nati's Avatar
Check the tightness of the u shaped bolts that latch the hood
Old Feb 5, 2020 | 03:31 PM
DJS's Avatar
DJS
Doesn’t this also describe the symptoms of a loose fastener on one of the cross braces?
Old Feb 7, 2020 | 05:34 AM
Unhingd's Avatar
Could be a number of things, all of which need to be checked out. Fortunately, of the possible issues mentioned so far, only the diff issue is problematic. The other two issues can be resolved in a matter of minutes.
Old Feb 10, 2020 | 02:30 PM
6036Craig's Avatar
Thank you
Old Feb 10, 2020 | 02:31 PM
6036Craig's Avatar
Thank you - Checked them they are v tight
Old Jul 9, 2020 | 11:42 PM
Velocity8's Avatar
Did you ever found out what caused it? I have the same issue.
Old Jul 10, 2020 | 12:05 PM
David Meier's Avatar
Cross braces on engine. I think it's a T50 fitting
Old Jul 10, 2020 | 01:00 PM
Velocity8's Avatar
I checked mine, the larger braces with 1 exposed t50 torx on each side and smaller brace with two t50s all seem tight. Although I only felt it with my hand and try to see if I can wiggle the braces.
Old Jul 10, 2020 | 02:32 PM
Unhingd's Avatar
Use a real wrench. They can feel tight by hand but still be allowing joint slippage.
Poison Ivy
Oct 29, 2019 07:04 PM
Sue Pete Wentworth
Sep 9, 2019 10:26 PM
TDOTDAN
Apr 9, 2019 12:09 PM
calvado
Jun 3, 2018 12:28 AM
bubsey
Jul 16, 2017 06:58 AM
