F Type Supercharger belt tensioner differences
Old Aug 25, 2023 | 10:23 AM
ufok's Avatar
Default F Type Supercharger belt tensioner differences
Good Day Ladies and Gents,
I have recently located the source of squeaking noise in my F Type supercharger belt.
The belt is most wobbly and the noise is the loudest around the tensioner area.
My F Type is an early 2013 model and had an old type tensioner C2D21154 with a 1412 mm belt, however is seems that later the tensioner was replaced with a modified unit C2D49666 but used a longer, 1438 mm belt.
Would it hurt to replace the old type, faulty tensioner with a brand new, but of new improved design tensioner? I would also replace the belt for a 1438 mm belt.
Old Aug 25, 2023 | 01:26 PM
clubairth1's Avatar
Community Influencer
I would check those part numbers with Jaguar. Be sure and give them the last 6 digits of your VIN as everything Jaguar does depends on that number. They may have superseded the old stuff.
Old Sep 29, 2023 | 03:47 PM
samit's Avatar
I was looking into this last year as well, and was told that Jaguar only sells the new tensioner unit. It should be fine to replace the entire assembly as long as you get the longer belt too. AFAIK the original tensioner is a Ford part, so there are non-OEM options too if you would rather not replace the entire assembly, but just need a replacement tensioner.
Robert Laughton
Dec 22, 2019 12:44 AM
capitaineInsano
Jul 27, 2018 07:38 PM
oldtvman
May 12, 2015 12:24 PM
mustangtyson
Jan 23, 2015 08:20 PM
spuddyo
Jul 29, 2013 09:20 AM
