F type tools in trunk
Old Apr 26, 2017 | 08:52 PM
swiftwilly's Avatar
Default F type tools in trunk
Got a 2014 off lease. It arrived with NO tools in the trunk other than the tyre air pump. Could someone provide a list of what should be there? I need to make sure that I get everything I need. And OH, it didn't have the manuals either.
Old Apr 26, 2017 | 09:03 PM
WhiteTardis's Avatar
if you don't have a spare tire then there aren't tools. In conjunction to the air pump, there should be a bottle of "fix a flat" in underneath the battery compartment tray lid. If you get a flat, you connect the bottle to the pump and it basically seals the puncture with goop from the inside so you can get to a proper service station.
As for the manuals, you should go back to the dealer that sold the car to you or they are available to download on the Jaguar website as PDFs.
Old Apr 26, 2017 | 09:29 PM
Unhingd's Avatar
Only 2 tools needed: cell phone and AAA card.
Old Apr 26, 2017 | 09:45 PM
stmcknig's Avatar
Or on the 2016 push the little spanner button in the headliner cluster and wait for Jaguar Assistance ?
Old Apr 26, 2017 | 09:54 PM
Misujerr's Avatar
Yeah, I was a little miffed that a $100,00 car doesn't have one tool. Nothing, nada, zip, zilch... But I guess at this level, they don't expect that you will lift a finger to fix anything? Just lift that finger to call for help
Old Apr 26, 2017 | 10:12 PM
Buckingham's Avatar
There is a spot for the wheel lock key also.
Old Apr 26, 2017 | 11:05 PM
CDSsilver's Avatar
In addition to the "fix a flat" glue, compressor and wheel lock, I also had a big threaded eyelet bolt (for towing if I recall correctly). I am not sure if it is supposed to be in the trunk, but mine was. Also, mine is a 2015 - not sure about other years.
Old Apr 27, 2017 | 12:48 AM
Negan's Avatar
2014 here. There is indeed a tow hook in one of the flush panel compartments left of the battery compartment
Old Apr 27, 2017 | 12:51 AM
17jag's Avatar
Carrying a spare on a trip is not an option unless you want to FEDEX your luggage! I did buy a jack and lug wrench from Jaguar, along with a flat repair kit. This way, if I get a flat, I can raise the car to locate the issue, and use a plug to seal it. Beats running the tire goop into the tire. I had to do this once on my MINI and it took 15 minutes in total, a lot more time efficient than waiting for a tow truck or AAA. Now if teh tire is beyond repair, well there is no option but to call a tow.
Old Apr 27, 2017 | 05:34 AM
jaguny's Avatar
Where is that?
Old Apr 27, 2017 | 05:35 AM
jaguny's Avatar
I have two tow hooks.
Old Apr 27, 2017 | 06:39 AM
Unhingd's Avatar
Better yet!
Old Apr 27, 2017 | 06:41 AM
Unhingd's Avatar
Originally Posted by jaguny
Where is that?
Right next to the depression for holding the tire goop.
Old Apr 27, 2017 | 06:43 AM
Unhingd's Avatar
The small one for the rear is to be discarded and never used (though I still have mine as well). It was designed to be used for initial vehicle shipping only.
Old Apr 30, 2017 | 07:29 PM
Burt Gummer's Avatar
Geico really does have a great alternative w/ their app. Flatbeds are not extra. About $9-$12/year.
aquifer
Apr 17, 2017 09:57 AM
wyte101
Apr 17, 2017 01:52 AM
TheSweeney
Apr 16, 2017 02:52 PM
Ace300C
Apr 10, 2017 05:58 AM
nilanium
Apr 9, 2017 10:42 AM
