F-Type ZF 8HP Transmission Fluid Change DIY
Old Jan 14, 2024 | 09:30 PM
Therock88's Avatar
Originally Posted by manuninja
Thanks so much for the guide and congratulations on doing it so well! However, by doing this, some of the oil will remain in the torque converter. Isn't it necessary to wash the gearbox with a special machine?
As Atwell suggested above...This is the approved procedure and keeps the tranny in top shape if you continue to do the maintenance. To do a "flush", you need special (expensive) equipment, and you will likely never get ALL of the fluid out, without tearing the transmission completely down.
Also, this is the procedure approved by the company (ZF) that manufactures these transmissions. As always, do what works for you.
DC
Old Jan 15, 2024 | 01:55 AM
manuninja's Avatar
Originally Posted by Carbuff2
No...assuming that you mean the flush that many shops promote.
If you do regular fluid changes, the new fluid will protect the innards and there will be no chance of clogging or issues caused by flushing. Just reduce the time/mileage between ATF replacement.
DC
Ah ok, at this point, since my car is 5 years old and 30,000 km, I think it is better to do an change of the transmission oil in the way you described, without any washing.
I think that if I repeat the operation in 2-3 years I could avoid creating residues inside the transmission.
DGL
Sep 8, 2024 12:05 PM
jahummer
Mar 12, 2021 10:10 AM
mdcliff
May 11, 2019 08:03 AM
AndrewG
Jul 4, 2018 06:48 AM
zaydog
Oct 26, 2013 10:03 AM
