Fault codes after replacing cooling pipes
Old May 2, 2025 | 09:04 AM
J444G's Avatar
Default Fault codes after replacing cooling pipes
After changing cooling pipes, my car cannot delete those errors: U0447-00 and P0118-00
Since it is at independent garage without JLR diagnostic, we are bit stuck... Anybody have idea what this might be?
Thank you in advance
Old May 2, 2025 | 11:10 AM
DJS's Avatar
DJS
Here are 2 references for fault codes:
Workshop manual
https://www.dropbox.com/scl/fi/o6d1x...=4kjygex2&dl=0
OBD guide
https://www.dropbox.com/scl/fi/p52g7...=yiqn8knn&dl=0
Old May 2, 2025 | 11:49 AM
dennis black's Avatar
20 Year Member
Did they remove the battery cables when they did the job,
the first code ignore
Old May 2, 2025 | 01:42 PM
J444G's Avatar
Thank you, it was a un-clicked connector to one of coolant temperature sensors.
All good and purrr now!
Old May 8, 2025 | 03:58 PM
pascal's Avatar
Probably you did not connect the (correct) ect (temp) sensor.
wenn deleted the symposer you can also have swapped the temp connector…. Bin there…😌
mesaboogieman
Jan 28, 2020 01:03 AM
melhookv12
Feb 15, 2019 10:42 AM
Mihael
Aug 16, 2010 10:35 AM
electraglide1600
May 5, 2009 03:13 AM
CDUB
Mar 14, 2009 10:34 PM
