Feedback through Floorboards When Changing Gears
Old Jul 16, 2022 | 08:28 AM
Dwight Frye's Avatar
Default Feedback through Floorboards When Changing Gears
Forgive me if this is a dumb question. It is something that i noticed the first time after the car was broken in and I ran it up to near redline through the first several gears.(2021 F Type R w/8 speed ZF auto)
When in the Dynamic mode, manual shift mode and using the paddle shifters if I am in the lower gears and floor it, run up to above 6000 RPM and change gears, I feel a strong bang or thump through the floorboard beneath my feet. It will chip the tires between the 1-2, and 2-3 gear changes too. It shifts very fast and quite hard and the 0-100 speed is pretty impressive.
Do the rest of you guys also feel that hard thump through your floorboard ? When not in Dynamic and with the transmission just in D I am always impressed with how smooth the ZF transmission is and how well the computer chooses the gears for whatever the driving situation is or from throttle input. When shifting manually in Dynamic it feels like a dual clutch auto with very positive and rapid changes.
Old Jul 16, 2022 | 09:25 AM
kb58's Avatar
It's almost certainly two components knocking together due to engine torque. Get the car on a lift and look around under the car with a flashlight, looking closely for "shiny metal", indicating contact between two items. It's "probably" one of the exhaust pipes hitting something, either the chassis or a heat shield. It's also possible that a loose bolt is allowing something to momentarily shift. My car had a broken engine mount, which allowed the engine to rise up on the left side and hit the hood under hard acceleration, but of course everything looked fine when sitting still.
Old Jul 16, 2022 | 02:34 PM
lizzardo's Avatar
I'd guess a bad engine mount too. A few here have reported failures.
Old Jul 17, 2022 | 08:44 AM
I sure hope nothing is broken. The car only has 5400 miles on it and has not been driven hard. I guess I better make an appointment with the dealer for an inspection.
I would like to drive another newer F type to compare though.
Old Jul 17, 2022 | 09:56 AM
lizzardo's Avatar
The engine mounts are hydraulically damped and there have been premature failures. There may be evidence of leakage, but you can also do a simple test. The first post in this thread describes that:
https://www.jaguarforums.com/forum/f...mounts-221412/
Old Jul 18, 2022 | 09:28 AM
Thanks lizzardo, I'll do the test as described in that other thread. I may be overthinking the situation, what I'm feeling may just be the result of the enormous torque that the V8 produces combined with the fast and hard shifting transmission when in the Dynamic mode as it is applying that power through the drive shaft and to the rear wheels.
No one else with a newer R model has noticed that ?
Old Jul 18, 2022 | 10:29 AM
355rockit's Avatar
I had a leaking motor mount that had caused a thunk each time I shifted under acceleration. After the mount was replaced the noise is gone.
dibbyandco
Jan 23, 2021 08:13 AM
Lukas Delfin
Dec 24, 2017 12:05 PM
Frizzle
Jul 26, 2015 10:47 PM
Doug.Holloway9
Dec 1, 2012 09:45 AM
egpaul
Oct 26, 2010 03:30 PM
