First Time JLR Owner - Forum Introduction and Build Thread
Old Sep 24, 2021 | 02:42 PM
MovesLike's Avatar
Originally Posted by NBCat
Have you inspected the cooling system for leaks? I don't see the mileage listed for the vehicle, but if it hasn't been replaced, the rear heater pipe between the cylinder heads is a common failure point that can lead to catastrophic engine damage.
Another area to inspect is the outlet pipe under the front of the supercharger and thermostat housing on the AJ133, which are also subject to leaks.
The car has just under 30kmi. Thanks for the tip, I have not looked with intent, but I will. I removed the outlet pipe connector when I was installing the intake Y pipe and did not notice any sign of leakage. Coolant levels have remained stable too.
I have an appointment at the dealer early next month to address what I suspect to be an issue with the telematics (bad key fob range and abnormal battery drain). I will be sure to get a second inspection from them as well.
Old Sep 27, 2021 | 07:51 AM
mrjohnt's Avatar
Originally Posted by MovesLike
They are the tinted facelift variety, which look much better than the previous generation of tail lights. What makes them E-codes are the amber turn signals.
I will do you one better:
do the tail lights look different during the day? I think you said they are tinted? Thanks!
Old Jan 20, 2024 | 02:34 PM
Ranger0fThNorth's Avatar
MovesLike, can you DM me? I am seeing this car listed for sale currently. I don't think the seller is you, since it seems you sold it last year. The seller is using pics from the car's old BaT auction, triggering my scam sense. The seller isn't answering, but I'm trying to determine if the listing is legit and, if so, how to reach the seller. Thank you!
Old Jan 20, 2024 | 04:20 PM
DJS's Avatar
DJS
You won’t be able to PM until you reach 5 or perhaps 10 posts on the forum.
Old Jan 20, 2024 | 06:07 PM
​​​​​Thank you DJS, I had wondered what the number was.
SonofGaladriel
Dec 23, 2020 09:54 AM
powerhouse
Jan 7, 2019 10:42 AM
dag82
Dec 6, 2018 12:33 PM
Fstbmw1
Aug 18, 2016 09:47 PM
Tel
Aug 15, 2015 02:55 PM
