H&R Lowering Springs on Base F-Type
Old Aug 6, 2018 | 09:21 PM
Jaggyx's Avatar
Originally Posted by Unhingd
I did not experience any perceptible difference in ride comfort when I installed the H&Rs.
Do you have a base?
Originally Posted by Itismejoshy
unlike unhingd my ride was effected, the GF notes often on how much better it rode before the H&Rs. i like it, but after driving a shiny new 400 for a few hundred miles recently i must say mine rides rough. i would also not recommend the H&R spring unless that is what your looking for. On the positive they look great! The body roll is virtually eliminated and that will contribute to slightly more wheel spin in a strait line hard launch with less of it being "absorbed" in the chassis. i don't have the base suspension so my opinion is based on my V8S with active suspension.
Interesting. I must admit that I do not know the difference between base and dynamic suspension just yet. I haven't done any research as to whether it's a magnetic suspension etc. but do know there's a difference between the dampers. I've also read that the H&R's do outwork the dampers when not in dynamic mode, hence me really searching for those with non-dynamic dampers.
Thanks for the insight!
Old Aug 7, 2018 | 06:08 AM
Unhingd's Avatar
Originally Posted by Jaggyx
Do you have a base?
No, I have the S with the adjustable dampers. And yes, the dampers in standard mode are over worked by the H&Rs. That issue went away when the much lighter Wortec rotors were installed. (I haven't quite got my brain around why that would be the case). The adjustable dampers are not magnetic. I believe they have simple valves that affect oil flow.
Old Aug 7, 2018 | 07:21 AM
fujicoupe's Avatar
Banned
This thread piqued my curiosity about what my base model would look like lowered, so I asked both my ex wives to sit in it while I viewed the car from different angles. Turns out I like things just the way they are, not with the wheel well liners pressing down on the tires.
Old Aug 7, 2018 | 08:33 AM
DJS's Avatar
DJS
Here's how the dampers work...
https://www.dropbox.com/s/05kci965sf...mping.pdf?dl=0
Old Aug 8, 2018 | 01:11 PM
Jaggyx's Avatar
Originally Posted by DJS
Cool. Will take a look. Thanks.
Old Aug 8, 2018 | 02:39 PM
Greggbhill's Avatar
I think I got it 😁
Old Aug 19, 2018 | 12:08 PM
Jaggyx's Avatar
Eibach springs installed along with 15mm spacers. Still a slight rake, but overall, really happy with the height.
Old Aug 20, 2018 | 06:00 PM
  #28
Crash808's Avatar
Looks great! How's the ride?
Old Aug 20, 2018 | 08:37 PM
Jaggyx's Avatar
Smaller bumps are slightly harsher. Almost as though a bit rougher around the edges, but that's to be accepted with a lowering spring so I'm still overall very satisfied. Due to the mild drop, I'm not noticing any pogo affect which I was previously afraid of either as it seems the damper still has a decent amount of travel.
Old Aug 23, 2018 | 07:12 AM
  #30
indietor's Avatar
i want do same can you put some other pics ? thx a lot
Old Aug 23, 2018 | 09:37 AM
  #31
Jaggyx's Avatar
Only one more unfortunately, but can snap more once back in TX.
Old Sep 14, 2018 | 04:05 PM
  #32
Jaggyx's Avatar
Almost forgot to add a few more pictures here:
Old Jan 5, 2019 | 10:19 PM
  #33
WJV's Avatar
WJV
Originally Posted by FType17
The Eibach kit is indeed the best option. First of all lowering the car too much reduces your suspension travel, secondly, the height sensors on your control arms will provide inaccurate feedback to your DSC. My car has Eibach springs and beefier anti-roll bars. The latter was what truy changed the car's composure in turns.
old thread, but I’ve got springs going on this week so its time for some Q&A.
Do these cars require any reprogramming from the dealer after lowering? Got me concerned about the active suspension and DSC sensors now.
Any tips for the install? I know you’re supposed to transfer all the stock rubber spring pads to prevent rattling. Anything else? Do you have to drop the rear axle?
Old Jan 5, 2019 | 11:09 PM
  #34
Jaggyx's Avatar
Not that I know of.
Yup, transfer all stock rubber pads and spring isolators. Other than that, it's a very straight forward install. No dropping of the rear axle needed.
Answers above in line.
Old Jan 6, 2019 | 11:38 AM
  #35
Unhingd's Avatar
+1 on all answers.
Old Jan 6, 2019 | 04:31 PM
  #36
WJV's Avatar
WJV
+1 on all answers.
Thank you both.
Old Oct 29, 2019 | 04:16 PM
  #37
powerhouse's Avatar
Right -- that's why it's been so tricky for me so far to grasp. The Eibach kit is the best option IMO with a .6 inch drop in the front and a 1.0 inch in the rear given the rake the car has in stock form.
Was it this set you used for your car https://www.tunershop.co.uk/eibach-p...ar-f-type.html
Old Oct 29, 2019 | 06:01 PM
  #38
DaddyDarren's Avatar
Here’s my V6 340 lowered on VAP (22mm) Springs & 15mm H&R Spacers. Wheel alignment was setup & adjusted to suit. It drives perfectly with absolutely no adverse effect...
Old Oct 31, 2019 | 04:17 PM
  #39
powerhouse's Avatar
Think that drop would suit me, Now my 4 pot is currently sitting on new conti sport contact 6 tyres, 305/30/20 rear and 265/35/20 front and 15mm H&R spacers all round, jaggyx would you have a link to the Eibach's you bought was it same as these https://www.tunershop.co.uk/eibach-p...ar-f-type.html
Old Nov 1, 2019 | 12:01 PM
  #40
Jaggyx's Avatar
I believe they only make one part number for the V6 springs.
https://eibach.com/us/i-7871-pro-kit...4-springs.html
Do some shopping around though. They can be had for much cheaper than $600.
