Headlamp flicker over bumps
Old Apr 16, 2022 | 07:31 AM
davidmaria1's Avatar
Default Headlamp flicker over bumps
As the title states, on a couple occasions. These are sharp bumps, not a mild undulating rise. If you live in a freeze thaw region you'll know what I mean. I've only driven it a few times at night, but twice I have seen a quick flicker. Not sure if it's the HID's or the running led's that flicker, and it's so quick I can't tell if it's one or both lights, but I suspect the HID's I turned the lights on this morning and banged around under the hood and checked the connections I could reach and was unable to duplicate the issue. This test was in my driveway with the car running. The switch is in the auto high beam position, so I'm going to set the lights to manual mode and see if that changes during a drive. I try to avoid bumps, and I won't intentionally hit any, so it may take a few rides.
Anyone else experience this?
Old Apr 16, 2022 | 07:49 AM
Carbuff2's Avatar
Don't forget to check the security of battery and ground connections in the trunk (boot).
An overwhelming cause of electrical gremlins are caused by voltage issues (even when your battery is 'good').
At the 2022 NY Auto Show, an electric bike spokesman was touting their battery control module. Of course, they sold it AS AN ACCESSORY.
They also admitted that the most useful 'lectric bike had pedals. You know...in case you needed to go uphill and your battery was weak...
Old Apr 16, 2022 | 08:59 AM
scm's Avatar
scm
But the point of an electric bike is it isn't electric powered - the motor is designed to give the pedaller a boost, it doesn't drive the bike itself. If you don't pedal, it won't move! Like your supercharger - it doesn't drive the engine, just gives it a bit of oomph.
Old Apr 16, 2022 | 09:16 AM
Good point. I'll start there. It's probably better than hitting the front end. I'm sure the neighbors were entertained.
Old Apr 16, 2022 | 10:03 AM
kb58's Avatar
Ensure that the bulb socket assembly is fully seated. It's possible that the lights aren't blinking off, but a loose bulb/socket assembly is physically moving and momentarily "re-aiming" the light beam differently. On a related note, remove the bulbs and ensure the socket electrical connection is clean, being sure to fully seat the connection when reinstalling. Note that I don't own an F-Type and am guessing about how the headlight assembly is constructed.
Old Apr 16, 2022 | 10:22 AM
It can't hurt to check. The left side is a bit more accessible than the other. The harnesses appear secure.
Old Apr 16, 2022 | 11:55 AM
kb58's Avatar
In electrical troubleshooting, a very easy test is the "wiggle test". That is, turn on the headlights, engine off, and wiggle every wire harness and connector you can get at. It's amazing what that can uncover and costs nothing. The problem on new cars of course is access, actually getting at the harnesses and connectors...
Old Apr 16, 2022 | 12:57 PM
lizzardo's Avatar
When my car was still in its first year I noticed that one of the headlights jittered over bumps. It turns out that the two bolts holding the back of the assembly had fallen out. Different than flickering off and on, but if the place I noticed it hadn't given me a clear view of both spots of illumination I might have misdiagnosed it.
Old Apr 16, 2022 | 01:13 PM
Exactly. It's so quick, I haven't had a chance to differentiate a wiggle or an on/off condition definitively.
Old Apr 16, 2022 | 02:22 PM
lizzardo's Avatar
Open the hood and try wiggling the back mount of the headlight assemblies up and down. In two minutes you'll know if it's the problem I had.
Old Apr 16, 2022 | 03:41 PM
I will. Second thing in the morning.
DeepPurple
May 3, 2024 07:43 AM
crbass
Feb 24, 2021 10:50 AM
New2Jag
Nov 21, 2013 03:35 PM
stanjag
Nov 13, 2012 07:24 AM
JagXster
Jan 8, 2012 01:29 PM
