​​​​​​​Headlight dull spot
Old Apr 17, 2026 | 01:53 PM
Kuhli's Avatar
Default ​​​​​​​Headlight dull spot
Hello, I've read a lot about microcracks here.
However, I've now noticed a dull spot on the right headlight of my car.
Has anyone had similar experiences and have any tips for repairing it?
Frank
Old Apr 17, 2026 | 02:35 PM
WhiteTardis's Avatar
Thats the UV coating deteriorating. You'd have polish and reapply a UV coating. Any headlight restoration kit should be able to handle this. This can can happen to any car.
Old Apr 17, 2026 | 02:39 PM
2018XF25T's Avatar
I'll run that with a headlight lens restorer kit. Lots of brands to choose from here in the states. You should see a local brand there in Germany. I recently did mine on my Land Rover. The outcome has been great.
Old Apr 18, 2026 | 10:16 AM
Valerie Stabenow's Avatar
Default Good luck with that!
Many threads on this topic in this forum. My 2017, built late 2016 suffered from the microcracking, as well as this spotting. I have jeweler's rouge-type polish (Novus) as well as the headlight polishing kit and neither one helped. In the forums, it was explained that it's not a surface issue, that the damage goes all the way through.
https://www.jaguarforums.com/forum/f...-lense-257789/
I complained loudly to my dealer, once I found out that I was still covered under a TSB, for replacement headlights. That has now expired, but I did get new headlights. You can also search to see what other owners have as suggestions for headlight LENS replacements. It involves heating the headlight to loosen the lens. You also can attempt to find a used one, but anything this old will probably also have the microcracking and clouding, unless the car was fairly new when parted out.
Just kinda disappointed in this otherwise LOVED car... no NAV update for my form factor (USB), TCU-based InControl Remote and Protect shut down.
and just a reminder... verify the JLR EXTENDED warranty on your O2 sensors before you think you have to pay for them. IIRC it's 15 years.
Old Apr 18, 2026 | 10:49 AM
Kuhli's Avatar
Thanks for your replies.
I had already suspected it might be the repair kit.
Thanks Valerie, also for sharing your experience.
Regards, Frank
selfmadexkr
Aug 24, 2024 02:30 AM
jdhwan80
Jul 18, 2024 06:35 AM
glencol
Mar 18, 2023 06:06 PM
gally
Feb 28, 2023 08:19 AM
mws
Aug 29, 2020 03:06 AM
