HELP - Battery disconnected trunk locked
Old Jul 8, 2017 | 05:28 AM
Lommi's Avatar
Exclamation HELP - Battery disconnected trunk locked
As the title suggests I have disconnected the battery in the rear of my 2014 f-type, and the trunk was closed so now I can't open the electrically opened tailgate.
What can I do ?
Old Jul 8, 2017 | 05:33 AM
Mulmur's Avatar
What can I do ?
Booster cables from another car/battery to the boost/charge ports under the hood.
Lawrence
Old Jul 8, 2017 | 05:52 AM
Lommi's Avatar
There doesn't seem to be any plastic cover under the trunk lid and I have tried to connect my battery charger to the front battery however it won't recognise the battery and the powered trunk still won't open. I have attached pictures.
Old Jul 8, 2017 | 05:53 AM
Lommi's Avatar
I disconnected the positive terminal in the trunk so that might be why it won't connect and charge?
Old Jul 8, 2017 | 07:43 AM
DJS's Avatar
DJS
You need a charged battery to connect to the jump points. If you connect a smart charger, it won't detect a battery (since none is present) and won't turn on. A dumb charger may work.
Old Jul 8, 2017 | 07:51 AM
Unhingd's Avatar
Connecting a real 6 amp battery charger to the under-hood posts will also work (****-ant little trickle chargers won't fire up anything on the car).
Old Jul 8, 2017 | 09:09 AM
Lommi's Avatar
As you guys suggested I connected another external battery to the car, and it worked perfectly
Old Jul 8, 2017 | 01:52 PM
RGPV6S's Avatar
They won't work if a battery is connected and it is too dead either. I can't remember what the minimum voltage has to be though.
