HELP - stuck injector
Old Mar 5, 2024 | 02:17 PM
trkyam's Avatar
Also note, there is a small margin of side to side clearance for the injecter to "wiggle" in side the head
I suggest doing this by hand, once you have a wiggle, the slide hammer will work.
Old Mar 7, 2024 | 06:47 PM
ThunderKitty's Avatar
I keep hearing what a nightmare these are. How long are these supposed to last before you have to replace?
Old Mar 7, 2024 | 07:04 PM
OzXFR's Avatar
Theoretically they should never need to be replaced but as we know they fail/leak/clog up sometimes.
Mainly due to carbon build-up on/in the injector nozzles, and then to rub salt into the wound the same type of carbon build-up can make them a bear to get out.
I suggest regular use of a fuel system cleaner additive, it seems to work to prevent or at least reduce carbon build-up.
I use Redline SI-1 and BG 44K, alternating between the two, roughly every six months.
Another one which is highly recommended around here is Techron.
I reckon it is cheap insurance against the pain of having to replace injectors and even if it doesn't really do a helluva lot it can't do any harm.
Edit - I forgot to add - many JLR dealerships chuck a can/bottle of BG 44K in as part of every scheduled service, and I can only guess the main reason they do this is to reduce injector problems.
Old Mar 7, 2024 | 07:08 PM
Putting ThunderKitty on the bottle...
Old Mar 7, 2024 | 07:19 PM
DJS's Avatar
DJS
I use BG44K once a year, before the annual oil change. Fingers crossed that it’s helpful.
Old Mar 7, 2024 | 07:57 PM
randyb's Avatar
Talked to a jag service rep, he recommends doing an Italian tuneup every 3-4 months
Old Mar 8, 2024 | 03:54 AM
scm's Avatar
scm
Months? Who has an F-Type and doesn't do that at least weekly?
Old Mar 8, 2024 | 06:50 AM
  #28
clubairth1's Avatar
Community Influencer
I also use Techron and BK-44. Still can't notice any difference?
Old Mar 8, 2024 | 09:44 AM
bjg625's Avatar
I used BK-44 and still lost fuel injectors, one one each side a year apart at about 27k miles. Both times I was high revving! I believe in the Italian tune up but that is when my injectors got stuck.
Old May 28, 2024 | 09:35 AM
  #30
clubairth1's Avatar
NBcat do you have what sizes the brass brushes should be?
We will need two sizes. The small one to clean the tip area out and a much larger one for the metal body.
I have not been able to find the dimensions of these injectors at least for the area's that need brushing?
Here are the area's I need to get the right sized brass brushes for.
Thanks to anyone who can provide these diameters.
Old May 28, 2024 | 11:05 AM
  #31
Ray Ray's Avatar
I will get them for you in a bit, anything else you want to know except how it tastes?
og part from 2015 R, injector production date: 2014
Old May 29, 2024 | 07:01 AM
  #32
clubairth1's Avatar
Ray Ray that was WAY more detailed than I ever expected!!
Thanks so much and great pictures too!
Old May 29, 2024 | 07:24 AM
  #33
Carbuff2's Avatar
Now, we ALL want to know what it tastes like.
Old May 29, 2024 | 07:37 AM
  #34
Ray Ray's Avatar
Saved them just for this moment!
If aged steak is any indication, it’s probably best paired with a glass of fine wine and a jar of grey poupon.
Old May 29, 2024 | 10:36 AM
  #35
scm's Avatar
scm
Probably pork ...
Old Dec 4, 2025 | 04:43 AM
  #36
pahar911's Avatar
Originally Posted by Obi
After 2 days of spraying pb blaster and slide hammer I used a crane. It worked
you should have used a JCB 😂🚜
Old Jan 12, 2026 | 04:24 PM
  #37
Olek's Avatar
Any ideas of that can be restored without pulling the head and taking it to a shop? These 2 injectors was a real pain to remove.
Old Jan 12, 2026 | 08:30 PM
  #38
randyb's Avatar
I used a brass brush and a little bit of corrosionX.
Old Jan 12, 2026 | 08:38 PM
  #39
Olek's Avatar
My concern is the oxidation(specifically cylinder 5), not the stuck tip of the injector. That is easy to push inside and catch with a magnet through the spark plug hole.
MattEletronics
May 16, 2023 07:19 AM
Life And Projects By Austin YOUTUBE
Jan 18, 2023 07:38 AM
Dustin Moorman
Jan 10, 2023 08:42 PM
Gus
Mar 4, 2017 10:16 AM
mystype04
Jul 12, 2013 03:08 PM
