Help with top
Old Mar 2, 2026 | 04:37 PM
cwo4uscgret's Avatar
Default Help with top
i went to lower my top the other day and the flaps, cover wings whatever they're called won't drop down leaving the top in limbo. I looked i had dropped a very thin windbreaker in the well; removed it and still had the problem.
the only other issue was the battery kept reporting a low voltage status; disconnecting and reconnecting the battery fixed that. After the top drops I don't hear any motor noises associated with lowering the flaps.
whars the issue, what's the fix?
thanks
Old Mar 2, 2026 | 06:08 PM
DJS's Avatar
DJS
First off, I would put the battery on a charger or maintainer. These cars do unpredictable things if the battery is a bit low or weak, so make sure the battery is good before looking elsewhere.
Old Mar 2, 2026 | 09:14 PM
Borbor's Avatar
Fully charge your battery. You have only killed off any non sleeping modules that may be causing a battery drain. You still have a flat battery that will retrigger shortly
Old Mar 6, 2026 | 03:57 PM
RRpip's Avatar
Low voltage confuses the top module. Even if battery seems fine now, it likely tripped a fault. Disconnect battery for 10 mins to reset module. If that doesn't work, check the fuse for the top.
Old Mar 12, 2026 | 03:27 AM
I fully charged my battery, checked the fuses they are fine this afternoon i disconnected the battery for 10 minutes and now I have no movement up or down on the top. I also have a "warning" top not latched do not exceed 30 or 35 mph. I didn't have that message before.
Now what?
thanks
Old Mar 13, 2026 | 02:46 AM
Bueller? Bueeler? Anyone? Thanks
Old Mar 13, 2026 | 03:08 AM
wachuko's Avatar
Have you checked for error codes with a scanner?
Old Mar 13, 2026 | 04:29 AM
Don't have a scanner. Something is wrong obviously. What type of scanner do I need?
Old Mar 13, 2026 | 05:55 AM
wachuko's Avatar
You can go to a local autoparts store and see if they would scan your cars for any codes. That is usually a free service, at least in a few stores in the US.
I am currently using this one: iCarsoft LR V4.0
Old Mar 13, 2026 | 09:28 AM
Carbuff2's Avatar
WAGs
1. There is nothing else in the top-well that is preventing the mechanism from FULLY retracting the top? Might need to pause it halfway down and look around.
2. Just the flaps? If only one, or one more than the other, might benefit from a drop of oil on the spring-loaded mechanisms. No motors involved AFAIK.
Old Mar 13, 2026 | 04:07 PM
JagCode3's Avatar
@cwo4uscgret Here is your clue - Where did you drop the windbreaker? You may have jostled a wire or connector when you removed it. Take a look with a flashlight.
After you scan for codes with your brand new OBD2 scanner as recommended above, also check out the manual to see how everything works - page 1680 onward (thanks as always to @DJS - the 5th member of the A-Team):
https://www.jaguarforums.com/forum/f...3/#post2837767
Old Mar 20, 2026 | 10:13 PM
So after charging the battery to its fullest and then disconnecting the battery for 10 minutes; now I have nothing WRT the top. I get a message on the instrument panel that says "top not latched; do not exceed 30 mph". Up or down the top doesn't do anything. Checked both fuses - both are ok.
Stopped at my local O'Reilly's the only code retrieved with the scanner is: ADDITIONAL ANTI-LOCK BRAKE SYSTEM DIAGNOSTIC TROUBLE CODE (DTC) C1109-24 Vehicle
Dynamics Control Switch - Signal Stays HIgh.
So once more to disconnect the battery for 10 minutes then if that doesn't work time to use my extended warranty and let Jaguar figure it out.
Thanks for all your advice.
Old Mar 21, 2026 | 09:06 AM
Carbuff2's Avatar
WRT the top windshield latches:
Tried a 'shmear' (light coating) of grease on the latch-hooks? Regular lubrication of many items (door & top latches, for example) is something I do, yearly.
If the mechanism isn't fully actuated the car's warning lights might be triggered, even if you can't lift the top by hand.
Old Mar 21, 2026 | 06:55 PM
bjg625's Avatar
Hope extended doesn't use "wear and tear" excuse!
POD XF
General Tech Help
21
Aug 10, 2025 12:06 AM
Leo_77
Feb 4, 2025 08:31 PM
john501
Mar 2, 2015 01:28 PM
Rique
May 8, 2012 09:05 PM
sbrantley
Jun 4, 2011 10:40 PM
