Highest mileage f type I’ve seen
Old May 29, 2024 | 01:48 PM
TylerKrad's Avatar
Default Highest mileage f type I’ve seen
Highest mileage f type I’ve ever seen. Anyone know one with more miles? This seems pretty impressive.
Old May 29, 2024 | 02:26 PM
peppersam740's Avatar
Not me.
Old May 29, 2024 | 03:12 PM
CJSJAG's Avatar
Has it had a new engine yet??
Old May 29, 2024 | 03:25 PM
TylerKrad's Avatar
nope, only thing I really saw that failed was the thermostat.
Old May 29, 2024 | 03:32 PM
alchemystic's Avatar
This F-type comes in at 133,074 miles...
Old May 29, 2024 | 04:05 PM
TylerKrad's Avatar
wow. Did u see a carfax with anything wrong?
Old May 29, 2024 | 04:08 PM
scm's Avatar
scm
Further proof of the unreliability of Jaguars!
Old May 29, 2024 | 06:16 PM
Listing on Car Gurus shows clean title and no accidents. Price drop to $12,995.
Old May 29, 2024 | 07:37 PM
TylerKrad's Avatar
not sure I would buy it but it’s definitely cool.
Old May 29, 2024 | 07:39 PM
TylerKrad's Avatar
that’s what I was trying to look into. They are great cars, of course if you do the coolant pipes they are even better.
Old May 29, 2024 | 09:07 PM
DJS's Avatar
DJS
Those are the highest I’ve seen. I’m around 87k miles, and I think there are a few on here around 100k.
Old May 29, 2024 | 09:45 PM
TylerKrad's Avatar
what have u had to replace if anything?
Old May 30, 2024 | 07:23 AM
DJS's Avatar
DJS
S/C isolator/coupler
I had the dealer replace the original plastic cooling pipes, and they indicated the water pump was weeping so they replaced it
Consumables: tires, brakes, spark plugs, brake fluid, diff fluid, wiper blades, TPMS sensors, one headlight bulb…
(Coolant was changed when they changed the cooling pipes)
Haven’t changed the transmission fluid yet.
My car was early (S/N 26xx) so there were a number of TSBs to fix little things.
Old May 30, 2024 | 09:02 AM
TylerKrad's Avatar
seems pretty good. I got the whole aluminum kit for the coolant. Just waiting to install it
Old May 30, 2024 | 10:02 AM
scm's Avatar
scm
You're 27k overdue!
Old May 30, 2024 | 10:52 AM
DJS's Avatar
DJS
You're 27k overdue!
Yup. The dealer said they preferred to only change it if there was a problem, and I didn’t want them doing work they didn’t want to do. I’m going to ask my indy if he’s done ZF transmissions, I’m guessing he has.
Old May 30, 2024 | 03:11 PM
sov211's Avatar
My dealer had no issue at all in changing the fluid in my S-Type a couple of weeks ago. That is a 4.2 litre V8 with the ZF 6 speed. Yes, the transmission is somewhat different but the process is not. I supplied the OEM transmission sump cover/filter and the ZF fluid.
I say this because there may be another dealer willing to do the work if you cannot find a ZF friendly shop.
Old Jun 7, 2024 | 07:39 AM
jcb-memphis's Avatar
Cool.
Am at 65k and hope to get to 200k.
These are Bosch/TRW/LEAR/ZF cars. Pretty much handmade with robot helpers on a line in England. The suspension is LR spec tough. In the real world on real roads, they are plenty quick and oh so beautiful to look at when you stop for a coffee or something. They are easy to live with as a daily yet are exotic - I consider mine a pragmatic supercar. I can get my huge suitcase into it and could never do that with a 911. Simple but important.
The coolant pipes, s/c coupler, and wear and tear are what you need to do...all of this is pretty normal and for a supercar (my brain) actually really cheap if you find an indy - they are reliable. Around here labor rates are all the same, so parts prices make the difference. It is shocking how expensive cars are these days so keeping one of these makes fiscal sense too.
Not sure how to say this, but there is a brilliance in the JLR design team that never gets the attention it deserves imho. Fun at normal speed. Tough in real world roads. Able to go from sedate to beast mode...a real two cars in one. And just beautiful beyond anything else out there at really any price (I'd take a singer and a few others too, so say under 250k dollars).
Spitfire 77
Oct 7, 2023 08:03 AM
khonarik
Jul 22, 2022 12:46 PM
oldole
Sep 22, 2021 03:41 PM
santacruz11
Jul 1, 2021 06:52 PM
racerx82
Sep 26, 2006 09:00 PM
