Highest revs on P
Old Feb 24, 2015 | 10:15 AM
kuba9449's Avatar
Default Highest revs on P
Hi
My f-type r on P or N is going only to 4k rpm. Is it possible to go to higher revs or rev limiter on park or neutral?
Old Feb 24, 2015 | 11:07 AM
Unhingd's Avatar
Originally Posted by kuba9449
Hi
No...and for good reason!!!!
Old Feb 24, 2015 | 11:18 AM
Tel's Avatar
Tel
Why on earth would you want to?
Old Feb 24, 2015 | 11:31 AM
Schwabe's Avatar
All 5.0 are limited to 4K revs.
Old Feb 25, 2015 | 02:25 PM
kuba9449's Avatar
Ok thanks.
Old Feb 25, 2015 | 03:27 PM
Unhingd's Avatar
What is the redline for the 5.0 under load?
Old Feb 25, 2015 | 04:45 PM
DJS's Avatar
DJS
I've tried reving mine in Park to make exhaust sounds (don't have switchable active exhaust, so it doesn't do much), and it doesn't seem to like it - feels like the engine is out of balance or something.
Old Feb 25, 2015 | 05:13 PM
buickfunnycar.com's Avatar
3-4k is the most you'd ever want to free-rev a motor that's not under a load...
Old Feb 25, 2015 | 11:17 PM
allenman85's Avatar
I've building race engines since '86. Never had an issue with "free rev" -- what exactly is the issue? My V8's turn 8300 rpm+/-. The valve train and crank does not "know" that it's free revving... sigh...
And to the OP's question: no, sadly. *Boring*. I wish they would have allowed more "free revs"
Old Feb 26, 2015 | 05:06 AM
Unhingd's Avatar
At specific engine speeds, destructive harmonics can be established on free revving engines, particularly when there are loose bearing tolerances. Under load, those harmonics are either fully mitigated or substantially damped to a point where it is a non-issue. Race engines are blue-printed, balanced, and built to sufficiently close tolerances that the harmonics are not a concern. Also, racing engines have to be rebuilt with sufficient frequency that the bearing tolerances don't loosen too much.
Old Feb 26, 2015 | 05:11 AM
Unhingd's Avatar
Rev limiting is accomplished by "killing" the igniton spark. So when you hit the rev limit the engine is actually "missing" causing it to run rough if you keep it at the rev limit.
Old Feb 26, 2015 | 08:33 AM
Foosh's Avatar
Yes, I was wondering why as well. In the performance world, newly-built engines are routinely bench, dyno-tested to measure flywheel hp and torque.
Old Feb 26, 2015 | 09:27 AM
Unhingd's Avatar
Yes, but only revved up to redline under load. That's how they measure the horsepower and torque: by applying a known load to the wheels.
Old Feb 26, 2015 | 02:22 PM
OzRisk's Avatar
If you ever get a chance to see it, there's a documentary on the Audi R8 factory (I think it's Megafactories, or something like that).
They stress test their V10 engines before putting them in the car, and run them for hours at the redline until they are literally red hot. That sort of testing is why the Germans are so renowned for reliability.
Old Feb 26, 2015 | 02:55 PM
RickyJay52's Avatar
And maybe why my 2004 Audi A8L and my wife's 2006 BMW 325 xi Wagon both have north of 180,000 miles on them - yes, separately - with very few problems along the way! Both still look fabulous and ride great. That's what I call a resounding endorsement for German engineering...and that's coming from a NY Jew. (Just a little - very little - levity).
Broken_Spanners
Dec 11, 2015 04:14 AM
carl purchase
Oct 14, 2015 06:14 PM
JTC3400
Sep 29, 2015 05:03 PM
yarpos
Sep 27, 2015 06:14 PM
