How is the arm rest removed?
Old Dec 31, 2017 | 12:09 PM
woodturner's Avatar
Default How is the arm rest removed?
I would like to temporarily remove the arm rest from my 2015 coupe. When the arm rest is raised there are four knurled (what I assume are machine screws) studs visible back by the hinges. My gut tells me that I will need to unscrew each of these but they won't budge using finger pressure and I fear I will scratch and mar them if I use something like needle-nose pliers. Am I on the right track here? How is the arm rest removed?
Old Dec 31, 2017 | 02:40 PM
Unhingd's Avatar
Pics please. I didn’t know the F type ever offered the armrests. On my car, the center console is already a bit too high without A supplemental armrest
Old Dec 31, 2017 | 03:47 PM
OzXFR's Avatar
I reckon you are on the right track.
The Workshop Manual centre console removal procedure simply shows a pic of the raised armrest with the four studs/bolts/screws highlighted (look closely and you will see they are about 3 cm long and go right through to the other sides of the hinges), so obviously they can be removed.
But exactly how you unscrew them without risk of damage is the $64,000 question!
Very carefully with needle nosed pliers may be the go.
Old Dec 31, 2017 | 04:01 PM
OzXFR's Avatar
Here's the pic from the Workshop Manual:
Old Dec 31, 2017 | 05:30 PM
woodturner's Avatar
Yep. Those are them. I shall proceed accordingly. Thanks.
Old Dec 31, 2017 | 07:34 PM
Unhingd's Avatar
Oh...you're referring to the compartment lid...sorry.
Old Jan 1, 2018 | 11:39 AM
F-typical's Avatar
The diagram appears to suggest that they aren’t threaded?
Old Jan 1, 2018 | 06:07 PM
Unhingd's Avatar
+1. Those pins are pressed in. It appears the forward pins can be removed with a drift pin from the outside, and then the hinge can be lifted to offer sufficient access to drive the rear pins out, also toward the inside.
Old Jan 1, 2018 | 06:26 PM
woodturner's Avatar
Thanks guys! I was able to make my mods without removing it.
Old Jan 1, 2018 | 06:28 PM
Unhingd's Avatar
Better yet!
1jagoff
Jul 30, 2010 07:20 PM
hafferf
Jul 28, 2010 11:33 AM
2002 XJR
Jan 7, 2010 12:37 PM
jjones91
Aug 19, 2008 09:47 PM
