How do I remove Valve Stem Cap on a 2017 F-Type
Old Apr 11, 2025 | 12:39 PM
LBCGirl's Avatar
Question How do I remove Valve Stem Cap on a 2017 F-Type
I'm losing air in a tire. I went to fill it but couldn't get the valve stem cap off. The guy who was there tried to remove it with a wrench. Are these caps locked on in any manner? I'm in a 20177 F-Type.
Old Apr 11, 2025 | 12:58 PM
Thunder Dump's Avatar
They're not locked. My guess is it is an aftermarket aluminum or metal cap (or plastic cap with metal threads) that hasn't be removed in a while. The dissimilar metals can corrode and the threads fuse together. Honda had a big issue with that years ago and stopped using metal threads on the caps. I would think rotating with a pair of pliers should be able to get it off (although you will probably destroy the cap), or you could try heating it. Worst case scenario is a tire shop can just replace the whole valve stem.
Old Apr 11, 2025 | 01:03 PM
LBCGirl's Avatar
Great. Thank you, Thunder Dump. I didn't want to start going at it to find out there was some special way to remove it, like pushing it in, etc.
Will get back out there with a wrench. The pressure has been going down, but very slowly. Maybe there's a nail hiding somewhere.
Old Apr 12, 2025 | 07:17 AM
Carbuff2's Avatar
Mix some dish soap & water into a small spray bottle, and spray the valve stem. Any leaks will result in beautiful bubbles.
If that is OK, remove the wheel/tire and inspect it for signs of damage. The soapy water can point out issues with any possible damage (cuts).
Regards the valve stem cap: apply some penetrating oil first.
I've had tire shops leave the fill valve inside, loose.
Old Apr 13, 2025 | 08:56 PM
LBCGirl's Avatar
Thank you! Was able to get it removed. Now we'll see if it holds the air.
Old Apr 13, 2025 | 09:11 PM
Valerie Stabenow's Avatar
Default Loose core?
I had tire leakage issue, turned out the core had loosened. A quick tighten resolved it.
diagram
https://www.discounttire.com/learn/valve-stems
Tool
Amazon Amazon
cpq100
Jul 17, 2025 09:08 AM
AlexE
Jun 5, 2023 11:07 PM
Alisher
Jul 5, 2021 06:08 PM
WhiteTardis
Feb 26, 2021 03:35 PM
Cbitugs
May 17, 2017 12:42 AM
