How to raise engine noise in cabin?
Old Apr 20, 2019 | 05:19 PM
maxiedaniels's Avatar
Default How to raise engine noise in cabin?
The v6 f-type sounds absurdly good from outside the car, but I’m disappointed with the lack of engine feel/sound from inside the cabin. I’ve tried dynamic+sport mode (passive exhaust). It’s almost like someone cut most of the low end out of the sound. It does sound better when it’s very high revs, but still feels strange to me, like it’s distant.
I saw one post where someone removed sound deadening to help more engine sound enter the car. If anyone has tried that, did it work for you? I realize road noise would increase but I don’t think that would bother me.
Aside from that, is there an exhaust modification recommended that doesn’t make things too raspy?
Old Apr 20, 2019 | 06:13 PM
Unhingd's Avatar
Add a VAP Valvetronic exhaust. It’ll provide plenty of internal sound with no raspiness if you keep the OEM downpipes.
Old Apr 20, 2019 | 06:26 PM
OzXFR's Avatar
And get the VAP larger crank pulley and tune, the SC whine goes from barely audible to "747 taking off".
Never mind the increases in power, torque, responsiveness and performance!
Old Apr 20, 2019 | 08:15 PM
teacoff's Avatar
I find a cost effective solution is lowering the windows to increase the sound inside......
Old Apr 20, 2019 | 09:23 PM
BruceTheQuail's Avatar
agreed, if we could lower the rear windows the problem would be solved. The sound inside is incredible if they are taken out (which I did in my XKR)
Old Apr 20, 2019 | 10:22 PM
jbajor's Avatar
Or..... get the Vert!!! Always a decision of listening to tunes or the exhaust symphony!
Old Apr 20, 2019 | 11:55 PM
Brava's Avatar
My car is so noisy inside I can’t speak to people when in dynamic mode; I need to turn off the exhaust for phone calls or passenger conversations
Old Apr 21, 2019 | 02:16 AM
Lolll. Unfortunately windows down doesn’t fix things for me.. interesting about the VAP mods, will research more. Thanks!
Old Apr 21, 2019 | 07:07 AM
scm's Avatar
scm
No-brainer!
Old Apr 21, 2019 | 08:23 AM
fujicoupe's Avatar
Banned
Have you looked into adding the Internal Sound Enhancement feature? I believe it's called a Symposer, although it may only enhance engine sounds and not exhaust notes--don't know as it is not an active feature on my car.
Old Apr 21, 2019 | 09:10 AM
Nati's Avatar
Pretty sure that's not a choice. I think it's on every F type.
Old Apr 21, 2019 | 10:13 AM
fujicoupe's Avatar
Banned
No, it is not on every F-Type; it's not on mine. From the build sheet provided when I purchased the car: "G27Z LESS Internal Sound Enhancement"
Old Apr 21, 2019 | 12:14 PM
lizzardo's Avatar
I wish mine had come without it, but fortunately it's really easy to defeat. It overpowers the "good" sounds (engine, exhaust) by adding drone.
Old Apr 21, 2019 | 12:35 PM
Nati's Avatar
Interesting. It's not a configurable option according to any of the order guides I've seen.
Old Apr 21, 2019 | 05:55 PM
Chawumba's Avatar
It's only like $10 of cheap plastic parts, and it produces much less value than that in terms of "engine" sound. Defeated mine,, but didn't really notice any difference.
Old Apr 21, 2019 | 06:27 PM
Unhingd's Avatar
You have the base V6?
RKB
Apr 25, 2019 07:10 AM
xenophobe
Apr 29, 2012 06:28 PM
scorch1
Mar 21, 2010 07:08 PM
Mark Rogers
Jul 27, 2009 02:38 PM
GordoCatCar
Apr 18, 2008 06:16 PM
