How To: VelocityAP Supercharger Crank Pulley
Old Jul 26, 2019 | 10:38 PM
  #81
OzXFR's Avatar
Originally Posted by Red_99
good to know, thanks. If I can find someone to do it, how long (aprox) would you say install took? 4rs? In terms of install, my understanding is that the 3.0L is the same as the 5.0L?
Yep, exactly the same on the 3.0 and 5.0.
Pro tip - remove the front under tray and the second/mid under tray behind that yourself before you take it in for fitting as that is where a large part of the time/labour cost is.
Based on my experience it's about two hours all up if you remove the under trays first and four hours if you don't (one hour to remove and another hour to refit).
Old Jul 27, 2019 | 07:20 PM
  #82
Red_99's Avatar
Fantastic advice!! Thanks guys, tremendous help!
Old Jul 28, 2019 | 07:31 PM
  #83
Red_99's Avatar
Originally Posted by Unhingd
High levels of various metals can indicate which specific components are subject to imminent failure (valves, rings, bearings). Water and fuel in the oil also indicate points of failure. Fixing the engine before a catastrophic failure destroys it is the real advantage of oil testing.
Just curious, but where would you go to have these oil tests performed?
Old Jul 28, 2019 | 07:52 PM
  #84
OzXFR's Avatar
Blackstone Laboratories, Fort Wayne Indiana.
You send them a small container of your used oil and they send you back a comprehensive report.
I can't seem to find a web page for them but I found their FB page instead: https://www.facebook.com/BlackstoneLaboratories/
Lance (Unhingd) uses them a fair bit.
Old Jul 28, 2019 | 08:39 PM
  #85
Unhingd's Avatar
They will send you free oil sample kits with prepaid postage: https://www.blackstone-labs.com/prod...bnqhikkyl))%2F
Old Jul 29, 2019 | 01:17 PM
  #86
Extra Orange's Avatar
Just finished this Saturday. Very easy install with a lift, 2 hour job at most. Without a lift I would guess more like 3-4 because of getting the second undertray removed and the need for good leverage when pulling back on the tensioner. Bolts on the pulley weren't as tight as I expected and re-running the belt was much easier without the intake Y-pipe on.
Old Jul 29, 2019 | 01:39 PM
  #87
Luc Lapierre's Avatar
Generally speaking, how often should one get these analyses? Let's say for a daily driver with a predilection for spirited driving and the odd day trip.
Old Jul 29, 2019 | 03:31 PM
  #88
Unhingd's Avatar
I have it done at every oil change.
Old Jul 29, 2019 | 03:35 PM
  #89
Candy Jones's Avatar
me too!
Old Jul 31, 2019 | 12:45 PM
  #90
Red_99's Avatar
I called somewhere that does oil analysis up here and when I ask for a level 1 analysis they said it would more broadly check for abnormalities, not specific to my 3L. Do you just compare 1 sample to thr previous ones or...?
Old Jul 31, 2019 | 12:46 PM
  #91
Red_99's Avatar
I don't have a lift but wow? 2 hours is fast!
Old Jul 31, 2019 | 12:53 PM
  #92
Red_99's Avatar
I don't have a lift but wow... 2 hours is fast! The 1 shop wanted 5 hours just to change that pulley.
Old Jul 31, 2019 | 06:41 PM
  #93
OzXFR's Avatar
At five hours I think they are having a lend of you and they don't really want to do it as they probably have never done this job before on a Jag.
Remove the under trays yourself and it should take no more than two hours, print off and take with you the instructions shown on this forum to show them how it's done, I have done this with such things as getting lowering springs fitted and it save the mechanic heaps of time and me heaps of money!
One tip - when I had it done I watched the mechanic (a very Jag experienced indy) and at one point he removed a black plate about 2" x 1" from under the gearbox and fiddled with something in the hole.
When I asked him why he explained that was the easy way to lock the crank, although he didn't explain exactly what he did, but maybe someone else here can explain.
Old Jul 31, 2019 | 07:26 PM
  #94
Unhingd's Avatar
Might be an access plate to the torque converter. Simple way to lock the crank on the MT is to put the car in gear.
Old Jul 31, 2019 | 07:32 PM
  #95
Unhingd's Avatar
I compare my results to my prior results to determine what the wear trending is. Blackstone also provides some useful observations and conclusions regarding what they are seeing on the report.
Old Jul 31, 2019 | 10:49 PM
  #96
Red_99's Avatar
Good call. I will do just that, and try to take off the lower tray on my own, prior to bringing in.
Old Aug 2, 2019 | 12:06 AM
  #97
lizzardo's Avatar
I've called around, but I can't seem to get anyone to install except one tunning shop that's light years away. Also, to get the new tune that incorporated the pulley, should i flash begore going in to the shop or after?
I do the same, but pull the sample about a month before my scheduled service so that I might have opportunity to have them check anything that might be questionable. So far, the only thing even a little off is that they might have used the "regular" Castrol synthetic oil on my second change (if memory serves) because everything still looked good but titanium was low.
Old Aug 31, 2019 | 01:21 PM
  #98
inmanlanier's Avatar
Extra Orange - how did your track day go? Since you are RWD - did you have fun with your tail end?
Any issues noted regarding the change on the track - water temp, ECU pulling back on power (perhaps due to detonation, other issues?)
Inquiring minds may wish to know since inquiring minds may have just placed an order!
Old Dec 16, 2019 | 11:50 AM
  #99
Red_rooster's Avatar
Default Pulley wrong length
hey guys, need some help!!
I have a 2018 v6. I'm trying to put the supplied belt on the new pulley but it won't fit. I was sent a belt that's the same size as the old belt.
what is the correct size for the belt I need?
Both belts I have are 1438mm. Shouldn't it be 1460mm?
Thank you
Old Dec 16, 2019 | 03:11 PM
  #100
RGPV6S's Avatar
I have a 2014 V6S. The original double sided belt on my car was 1412mm. The double sided belt VAP sent with the crank pulley was 1461mm and was too long - it slipped badly under hard acceleration. I got a Gates DK080568 which was 1442mm and double sided and it worked. With the original belt the tensioner was about in the middle of its travel. With the 1460 belt it was almost out of travel. With the 1442 belt it was back in the middle.
Since your belt was 1438mm you probably will indeed need a 1460 belt.
BTW are you sure you are properly mounting and routing the belt? Are you sure you are fully compressing the tensioner? Its really easy to get the belt caught on the outer rib of one or more of the pulleys which might make it seem short.
