HPFP or Injectors?
Old Apr 17, 2024 | 02:07 PM
Tamaren's Avatar
Default HPFP or Injectors?
Another issue that popped up this week- 2016 3.0 base Rough starts. Sometimes it's fine. Hot starts after an hour seem to be worse. But it'll stumble it's way to starting and then be fine. Sometimes it throws a Cyl 5 and Cyl 4 Misfire code, along with a "various misfire" code.
I replaced the 4,5,6 bank injectors about 15k miles (8 months) ago.
Always throws both 4 and 5 codes together, so my thought was HPFP, but I also thought that would give a low pressure code as well- Might not, Might just be bleeding off pressure.
I have some Injectors I ordered in. Any way to tell if HPFP is acting up? It would be odd if two new injectors started to have issues together, is my thought.
Thanks!
Old Apr 17, 2024 | 02:45 PM
2000JagLvr's Avatar
Thanks!
Bad coils? Try swapping coils 4 and 5 with other cylinders see if the problem moves.
Old Apr 18, 2024 | 06:13 PM
randyb's Avatar
Have you checked the fuel pressure at the rails?
Dustin Moorman
Jan 10, 2023 08:42 PM
Guilherme Ribeiro
Apr 22, 2022 05:04 PM
silvertonesx24
Oct 4, 2020 11:01 AM
Darealwoody
Aug 22, 2019 11:38 AM
Chico Mendoza
Sep 21, 2018 12:33 PM
