Interior Lighting on Base F type - Anyway to toggle on?
Old Aug 17, 2023 | 11:01 AM
HowYouDoin's Avatar
Default Interior Lighting on Base F type - Anyway to toggle on?
I have a 16 Base F Type. I saw there is LEDs under the door handle (Above "Surround Sound" speaker) and on the passenger "oh S**t" handle but there is no software option to turn it on. I saw a few threads talking about it but has anyone figured out how to get these prewired LEDs to turn on?
Old Aug 17, 2023 | 11:23 AM
Tracy Rominger's Avatar
Mine work through the ambient lighting option that allows them to change colors. When Im driving they do stay on all the time and turn red when i go into sports mode
Old Aug 17, 2023 | 11:31 AM
HowYouDoin's Avatar
Sounds like you have the configurable version that came on higher trim cars. What year/trim is your car?
Old Aug 17, 2023 | 11:44 AM
WhiteTardis's Avatar
16MY did not come with configurable lighting for the base model. You would need to edit the CCF files of the car to enable it but ALSO install the LEDs for the configurable option. JLR parts catalogue has two part numbers for the LEDs. One for the base (which is just the blue/green) and the other is for configurable.
Old Aug 17, 2023 | 11:49 AM
scm's Avatar
scm
Really? Mine only turn red in dynamic mode.
Old Aug 17, 2023 | 12:32 PM
HowYouDoin's Avatar
what if I don’t want configurable. I just want the blue LEDs (I think they’re already installed from the looks of it) to turn on. I saw a post where someone just spliced in a wire in the door to turn on the LEDs above the “surround sound” badge but I couldn’t see the details of where the wires were connected.
Old Aug 17, 2023 | 04:47 PM
scm's Avatar
scm
I think a member on here had just that done by her dealer ... Valerie Stabenow?
Old Aug 17, 2023 | 05:27 PM
Thunder Dump's Avatar
My '18 Base had the blue/green lights and they worked from the factory. They weren't configurable (other than turning red in Dynamic mode) but there was nothing needed to activate them. I don't know if the earlier years were different but you could start by checking fuses to make sure you don't have a blown fuse that's keeping them from coming on.
Old Aug 17, 2023 | 05:32 PM
HowYouDoin's Avatar
I don't think it's a fuse issue, I went through and checked all the fuses in the passenger footwell while hardwiring a dashcam.
Old Aug 18, 2023 | 05:37 AM
DJS's Avatar
DJS
I believe a few years ago, a few people discovered they had the blue lighting, but it didn’t work from the factory. You might be able to find the thread.
Old Aug 18, 2023 | 09:23 AM
Valerie Stabenow's Avatar
Default Excerpt from post
https://www.jaguarforums.com/forum/f...-180864/page3/
Thanks to all the research and researchers here, along with the posts and photos, my local Jaguar Tech got to the root of what was preventing those door handle and grab handle lights from coming on. The Tech ran a guided self-test to initialize an offline module. Once initialized, the lighting worked perfectly. He referenced B1412-96 Quiescent Relay. I looked this part up on Google and there are many posts regarding issues with this unit. This is on a MY2017 Base with Premium.
Old Aug 18, 2023 | 11:27 AM
HowYouDoin's Avatar
As much as I want to peruse this, My car is out of factory warranty and I don't feel like paying $250 diag and then probably just as much of an "software installation" fee. I wish there was a DIY way of doing this.
Eric325ci
XE ( X760 )
22
Jan 23, 2023 10:15 AM
zachstu
Sep 8, 2022 08:55 PM
scjordan1969
Jan 10, 2022 04:31 AM
stmcknig
Jun 30, 2021 10:25 PM
tinumon
Oct 26, 2017 02:52 AM
