Interior Tweaks
Old Mar 27, 2017 | 01:40 PM
WhiteTardis's Avatar
Default Interior Tweaks
I have the performance seats, interior black pack, extended leather pack and red stitching. I wanted to break up the all black of the center console. So I ordered the original "Ignis Orange" engine stop/start button that came on earlier F-TYPEs. Cost of the button was about $28 picked up from my local retailer
Installation is straight forward. You really need a trim panel removal tool to remove the center console trim as its fitted on very tight. Afterwards everything just snaps back together.
I also wanted a more uniformity with the interior lighting. The footwell lights use a traditional 194 filament bulb. The output is very yellow. Kind of mismatched looking considering that the overhead map lights are white LEDs. I ordered 4500K/85lumen LEDs. 4500K is white enough to match the overhead map lights and 85 lumens is just bright enough where its not too obnoxious or look aftermarket. I ordered the LED's from SuperBrightLEDs. Knowing how electrically sensitive these cars were, I went with a CANBUS compatible setup to avoid any error codes or issues.
https://www.superbrightleds.com/more...ofit-car/1127/
Replacing the footwell lights was a bit of a pain. The bulbs are tucked away to point where you need stick your head in the footwell to see what you are doing.
Before:
Everything is all black. Nothing wrong with that. Just a bit boring.
After:
Just enough color to break up all the black:
LED in the footwell before/after. Note that the light output is very similar but much whiter.
Old Mar 27, 2017 | 01:47 PM
stmcknig's Avatar
Do you have the part number for the ignis start/stop button ? I think I might have to do the same thing...
Old Mar 27, 2017 | 01:53 PM
malbec's Avatar
Funny, the one thing I don't like on my car is the orange start button. Wish it were black
I ordered metal paddles in place of the orange ones too.
Old Mar 27, 2017 | 01:55 PM
ShaunPA's Avatar
Same. I want to replace all of the orange bits in the interior to black.
Here you go! I was surprised at the low cost of the button considering how expensive other parts are!
Old Mar 27, 2017 | 01:56 PM
Are you interested in parting ways with the Orange paddle shifters say for my black Stop/Start button?
Old Mar 27, 2017 | 02:39 PM
supercat'dXKR's Avatar
I will trade my black button for an orange one if anyone is local southern cal.
Old Mar 27, 2017 | 02:46 PM
CRS 123's Avatar
Or maybe the silver from the XE? They should be compatible?
CRS
Old Mar 27, 2017 | 02:52 PM
CRS
I didn't even consider that! But upon examination of the XE parts diagram, it appears the button is integrated into that panel.
Old Mar 27, 2017 | 05:53 PM
malbec's Avatar
I'm in England. The orange paddles feel very cheap and light. Thought I'd Put them back on the car should I buy a new one in the future.
Otherwise would trade, sorry.
Old Mar 27, 2017 | 06:28 PM
Burt Gummer's Avatar
Thanks for the tip on the footwell lights - ordered those. Those about going with blue lights, but stuck with white.
Burnt my hands a couple times running a feed wire on that hot little stock bulb under there. Love LEDs. Just upgraded my T2 pinball to all LEDs!
OzXFR's Avatar
Yep, one of the first things I did was to replace the horrible sickly yellow footwell light bulbs with bright white LEDs, I used COB versions. As you say they were a PITA to get at, in my case especially the passenger one (LHS on my car), it took a good 15 minutes of squirming around on my back with my head right up under the dash to get it done, it really is jammed into a very tight spot. I also fitted Growler/Jaguar logo projector puddle lights in the door sills, very quick and easy to do, not that expensive and adds a nice bit of bling.
It also makes me wonder why Jaguar fitted those horrible yellow bulbs in the footwell lights, when all other secondary lighting in the F-Type is white LEDs. Unlike my XFR which had a million horrible yellow bulbs and no white ones so I swapped every damn one of them out for white or blue LEDs!
Old Mar 27, 2017 | 06:30 PM
White is the way to go. It matches the overhead lights and looks OEM. Driverside is easy to replace. Passenger side is a pain.
Old Mar 27, 2017 | 06:34 PM
Pics and link of where you got them?
Old Mar 27, 2017 | 06:49 PM
Love the Puddle Lights however they might be a little much with these illuminated BLUE letter plates. Comeon Jag - red car - only blue on the whole car .... oh well. That's why I thought about BLUE under dash/footwell lights so the blue wouldn't look so out of place. (Red and Black car - why Blue, oh well)
Old Mar 27, 2017 | 06:54 PM
BruceTheQuail's Avatar
I wonder if you can get ice blue puddle/footwell lights to match the door etc lights. That'd be pretty cool.
Unless you were looking for a vein, I suppose.
Old Mar 27, 2017 | 07:19 PM
OzXFR's Avatar
Yep, of course you can, they are the same T10 wedge W5W bulbs as elsewhere.
For example: 2x 12V T10 W5W 194 168 COB Ice Blue LED Canbus Car Side Wedge Light Lamp Bulbs | eBay
Old Mar 27, 2017 | 07:33 PM
OzXFR's Avatar
I just tried to take some pics in my garage but no go, my camera flash just completely wiped out the logo every time.
These are the ones I bought, nearly 6 months ago and never a single hiccup: 2x Laser LED Car Door Ghost Shadow Projector Lights For Jaguar F-Type 2013-2015 | eBay
Old Mar 27, 2017 | 08:26 PM
domino_z's Avatar
i always wanted the silver shifter base for my R, but after seeing what's involved to get it out, i kinda got over it
i used the osram 5000k footwell leds, matches oe interior lighting perfectly, and swapped out the plastic console trim for oe carbon - made a big diff
Old Mar 27, 2017 | 10:56 PM
zmoothg's Avatar
Actually I just installed the illuminated puddle lights today, they are not the same T10 wedge bulbs. Changing the light color would be nearly impossible.
