Jaguar Mechanic Add-on question
Old Apr 28, 2023 | 12:40 PM
Shagman82's Avatar
Default Jaguar Mechanic Add-on question
Hi all!!
I took my 2017 Jaguar F-Type R (30K miles, 5.0l V8, AWD) into the good local European car mechanic for an oil change. Just got the report back and they are offering me some of these additional services and I wanted to get the forums opinion on them. I figure I am at the 30K mile mark some of these may be warranted, but don’t really want to spend money unnecessarily ( says the guy that bought a jag lol).
I appreciate any help or guidance and FWIW, I was thinking about doing the coolant flush and fuel induction, but happy to be swayed one way or the other.
Old Apr 28, 2023 | 01:13 PM
Thunder Dump's Avatar
If the brake fluid has never been changed then that's definitely overdue (~every 3 years) and that's not a bad price if you can't do it yourself.
Old Apr 28, 2023 | 01:32 PM
Shagman82's Avatar
awesome, thank you so much and I will get that done! Very much appreciated!!
Old Apr 28, 2023 | 07:04 PM
uncheel's Avatar
Yes on the brake flush. No on the other two. Coolant should be good for another 3 years. Put in a can of BG 44k Platinum fuel system cleaner for good measure.
Old Apr 28, 2023 | 07:17 PM
OzXFR's Avatar
This.
Old Apr 28, 2023 | 07:40 PM
lizzardo's Avatar
I find it interesting that they are suggesting changing the front differential fluid but not the rear. I don't have a front diff so can't speak to that part but it wouldn't hurt to change the rear diff fluid, just be sure they use a fluid that meets specs. There's not a lot of fluid in there and it can get worked pretty hard.
Old Apr 29, 2023 | 12:24 AM
DNAer's Avatar
Brake flush and instead of the front diff have them replace the rear diff fluid. If you can’t find the appropriate BOT fluid, Ravenol has one that meets the BOT spec. I think I would bring in my on rear diff fluid just to be sure… but that is just me.
Old Apr 29, 2023 | 06:04 AM
scm's Avatar
scm
The schedule for my MY18 is rear diff every 4 years, front diff every 9 years and transfer box every 3 years.
Old Apr 29, 2023 | 10:48 AM
Shagman82's Avatar
This is awesome advice everyone, thank you so much for the input! The reason rear diff isn’t showing up is I already had that done a few months ago. I ended up oil change, coolant flush and brake fluid change!
thank y’all so much for the help, y’all rock!!
SonofGaladriel
Feb 9, 2021 11:02 AM
amenen01
Oct 18, 2020 02:31 PM
johnnymike
Sep 6, 2019 02:43 PM
PolkNole
Jun 14, 2016 01:21 PM
PolkNole
Oct 18, 2015 09:10 AM
