Keyfob Not Working When Cold?
Old Feb 4, 2018 | 11:36 AM
PolkNole's Avatar
Default Keyfob Not Working When Cold?
Every time my keyfob gets cold (like when its below 50 degrees), it doesn’t work. I have to warm it up for a few minutes with my hands, and then it works fine. Happens every time I let it get cold. Has this happened to anyone else??
Old Feb 4, 2018 | 12:30 PM
Suaro's Avatar
Interesting. Mine didn't work this morning either, and we were above 50°. But the second one worked. Time to read the manual!!
Old Feb 4, 2018 | 02:07 PM
DJS's Avatar
DJS
Time to replace the battery?
Old Feb 4, 2018 | 02:51 PM
Suaro's Avatar
Ah, I was just reading the manual, and there is nothing about replacing the battery. Just "talk to the service department". I did try the "back-up" technique where you press the fob to the dash below the truck release/fog light switches to no avail.
Old Feb 4, 2018 | 03:09 PM
mshedden's Avatar
Small batteries lose power in the cold, warming them allows them to work a little better when they are marginal. Most likely you need a new battery.
indietor's Avatar
replace battery i also had that problem and i fix with changing battery
Old Feb 4, 2018 | 08:39 PM
Frenchy's Avatar
1. Suaro writes: “Ah, I was just reading the manual, and there is nothing about replacing the battery.”
Quote from manual, or at least from mine (MY 2016): “When the battery needs replacing, there will be a significant decrease in the effective range and the message SMART KEY BATTERY LOW is displayed in the Message center. To replace the battery…,” etc.
2. After you manually warmed up the fob and started the car, did you get the message in the message center?
Old Feb 4, 2018 | 09:31 PM
OzXFR's Avatar
The key fob ("smartkey") battery is a piece of cake to change, details on page 13 of my paper copy Owner's Handbook, but for some strange reason it doesn't show in the electronic copy.
Old Feb 4, 2018 | 09:55 PM
PolkNole's Avatar
Great stuff everybody! No, I got no low battery message. But I think I’ll change the battery with the steps given above. Thanks!!
Old Feb 4, 2018 | 11:44 PM
zmoothg's Avatar
I have a new battery in my remote and I'm in Cali and the car takes about 10-15 secs sometimes to realize I'm telling it to lock. Only happens on lock. Percy otherwise
Old Feb 5, 2018 | 10:59 AM
Suaro's Avatar
Let me add my thanks also. That graphic is not in my manual.
Old Feb 6, 2018 | 06:37 PM
Dogbreath!'s Avatar
Ijust replaced the battery in mine. No warning light. Car just refused to start even with the Fob in the emergency position. New battery fixed it.
Old Feb 6, 2018 | 06:58 PM
Suaro's Avatar
Dogbreath! Good thing you were not in the shopping center parking lot when it decided not to work. I have always thought that mercury batteries were good for about three years, but I think a little preventive maintenance is called for here, changing the batteries every two years rather than waiting for a message or a serious inconvenience. As I have said before they are idiosyncratic machines.
Old Feb 6, 2018 | 07:12 PM
OzXFR's Avatar
Yep, when I got my two year old F Type one of the first things I did was to replace the batteries in both fobs as my previous experience with two XFs told me those fob batteries don't last much more than about three years.
Old Feb 7, 2018 | 08:38 AM
DJS's Avatar
DJS
No mercury batteries anymore, CR2032 is lithium. Shelf life is at least 7 years, so I guess they're dying from use. Mine will be 5 years old this spring - sounds like a good idea to change them.
Old Feb 7, 2018 | 02:25 PM
HalcyonDays's Avatar
Happened to me in front of a restaurant, where several hot chicks were admiring my car. Valets couldn't open car with the fob. Left standing there warming the fob in my hands. I am one cool guy.
Bcrary3
May 10, 2015 07:46 PM
vdpnyc
Nov 8, 2013 01:38 PM
denisecdb
Apr 10, 2012 11:08 PM
maikal_0011
Aug 16, 2010 09:45 PM
95XJ6
May 4, 2010 08:02 AM
