Looking for Charge Cooler o-ring seals
Old Apr 2, 2026 | 11:53 PM
MK-Ftype's Avatar
Default Looking for Charge Cooler o-ring seals
So I disassembled my charge air cooler when getting ready for my vap harrop 2300 swap. I cleaned it up and powdercoated it. I did run into a problem. When disassembling and removing the heat exchangers, there's an o-ring on each inlet and outlet for the heat exchanger. All 4 of these o-rings broke when removing with my seal puller tool. They are not normal o-rings, as there's a little flange and super thick. They look similar to aj811539 but quite a bit thicker flange, and slightly smaller ID of about 11mm. There's nothing in the part catalog or anything resembling them. Am I SOL?
Old Apr 3, 2026 | 06:34 AM
jisamtems's Avatar
It sounds like those o-rings are a specialty part, especially with the thicker flange and smaller ID. If they aren’t listed in the catalog, your best option might be to measure carefully and source custom o-rings from a specialty seal supplier. Alternatively, contacting the manufacturer or a dealer for part references could save time.
eubie67
Mar 12, 2026 06:55 AM
RaceDiagnostics
Apr 13, 2025 10:11 AM
no1
Mar 18, 2023 01:16 AM
jackra_1
Jan 20, 2020 04:10 PM
LnrB
Aug 17, 2015 09:22 AM
