Low battery and gas refuel
Old May 19, 2018 | 08:30 AM
jaguny's Avatar
Default Low battery and gas refuel
I'm still,having low battery warning messages after disconnecting the battery ground. Wondering if I disconnected it long enough? Would a low battery somehow affect cars ability to allow refueling? After using four different pumps at the station I regularly use (non- ethonal) I gave up. Drove the car about 4 miles and refueled with no issue. First station did say they were having some issues, but I used a pump right after another customer successfully refueled.
Old May 19, 2018 | 09:22 AM
lizzardo's Avatar
I can't see any relation between low battery and refueling. I suspect the station was indeed having problems and the car before you was just far less sensitive to it than the F.
Disconnecting the battery resets the module, but if the battery is actually low you'll need to get it fully charged before that warning will go away. Did you put it on a charger or go for a reasonably long drive afterwards?
Old May 19, 2018 | 12:15 PM
jaguny's Avatar
Yes, put on ctek, and 180 mile round trip.
Old May 19, 2018 | 12:19 PM
lizzardo's Avatar
Maybe your battery is actually low (failing). Mine needed to be replaced just after the two year point, at 18K miles.
Old May 19, 2018 | 01:26 PM
jaguny's Avatar
Did it get replaced under warranty?
Old May 19, 2018 | 02:36 PM
lizzardo's Avatar
Yes, covered under warranty. I actually went in with a different complaint: intermittent Adaptive Dynamics fault, Auto Start/Stop not working. They called it as the battery, and the problems went away.
Old May 19, 2018 | 06:18 PM
jaguny's Avatar
I just redid the battery ground disconnect and am recharging on ctek. One more round.
bocatrip
Oct 23, 2024 06:40 PM
1964Daimler
Sep 8, 2015 11:54 PM
o2manyfish
Jul 22, 2014 08:16 PM
coastaljag98
Nov 7, 2012 12:16 AM
svldvc
Feb 12, 2011 01:46 AM
