Mina Gallery intake kit
Old Jul 13, 2019 | 06:05 PM
Holy F type's Avatar
will this increase the supercharger whine?
Old Jul 13, 2019 | 07:14 PM
Unhingd's Avatar
I’m guessing yes, since the silencer sections won’t be there anymore.
Old Jul 14, 2019 | 01:29 AM
Tel's Avatar
Tel
Originally Posted by Unhingd
Yes, but probably no more than another pound or two. I will weigh carefully.
But you have lost loads of added weight by removing the OEM filters right?
Old Jul 14, 2019 | 01:32 AM
Tel's Avatar
Tel
Should increase the high frequency noise and the low down induction 'roar'.
The silencers and resonators in the OEM plastic items are designed to remove those two factors.
How noticeable it would be to the human ear in the cockpit is questionable.
I don't really care too much, what matters to me is shedding weight, and the engine bay looking like an engineered area rather than a digital, plastic, robot created POS ;-)
Old Jul 14, 2019 | 01:51 AM
OzXFR's Avatar
I've commented about this before and never got a response but I have trouble getting my head around how a different induction tube set-up could possibly increase SC whine. Induction roar most definitely yes but SC whine??? I suspect many here are conflating the two.
In a past life I had a couple of NA V6 cars and I experimented with removing the intake snorkels on them and the induction roar became insane, very loud and very deep.
But I didn't leave them that way for long as it seemed very likely the intake air was now a fair bit hotter seeing as the intake opening was now well and truly in the engine bay vs the snorkel picking up outside air.
Old Jul 14, 2019 | 03:33 AM
Tel's Avatar
Tel
Post
Resonance/Absorption - The best analogy I can give without getting to deep....Blow a raspberry as if you are going to blow a trombone down a plastic tube.
Now do the same with a piece of metal tube....hear the difference?
The metal tube will sound much crisper and raspy, the higher frequencies being bounced off the internal walls, whereas the plastic absorbs them to a certain degree.
Apply that methodology to the pipework on our cars and you're there.
Old Jul 14, 2019 | 03:44 AM
OzXFR's Avatar
Yep, makes perfect sense, but I still don't see what that has to do with SC whine!
Maybe I'm just too dense to understand!
Edit - some quick searching on the interwebz for "what causes SC whine" didn't come up with any definitive answer with opinions all over the shop, but the best I could figure out it is caused by the SC rotors spinning very closely together and pretty damn fast which causes noise (sound), and somehow that sound travels back up the intake tube(s) and out the end of them, so that fitting smaller air filters and air boxes and especially cone filters changes and accentuates that sound.
And metal intake tubes will change and accentuate this even further as explained by Tel.
Makes some sort of sense I suppose as the speed of sound is faster than the speed of the air coming in the intakes and through the tubing to the SC.
Old Jul 14, 2019 | 04:28 AM
  #28
jaguny's Avatar
It sounds (pun intended) like the Unhinged R&D shop will have this answer soon. I like the upgraded looks of the set up for sure. If it sheds a few pounds that would be good too. Added heat would be an issue though.
Old Jul 14, 2019 | 04:45 AM
OzXFR's Avatar
Originally Posted by jaguny
It sounds (pun intended) like the Unhinged R&D shop will have this answer soon. I like the upgraded looks of the set up for sure. If it sheds a few pounds that would be good too. Added heat would be an issue thought.
This worry about added intake air heat from using metal intake tubes instead of plastic comes up a lot, and as best as I can figure out it's not a problem.
Once you increase speed above a crawl the flow of fresh air through the intake(s) is too fast for the metal intake tubes to make any measurable difference to the temperature of the intake air, and they are also being cooled by external air flow.
At a stop and idling maybe some increase in intake air temp but so what, you're not looking for max air density and hence O2 volume while idling.
Also, have you felt how damn hot those plastic intake tubes get when the car is stopped (heat soak) - probably not much cooler if any than metal tubes!
Old Jul 14, 2019 | 12:24 PM
  #30
Unhingd's Avatar
The OEM filters remain in place with the Mina tubing kit.
Old Jul 14, 2019 | 01:24 PM
  #31
Unhingd's Avatar
You all got me thinking about taking temp measurements. Instead, the before/after dyno will be a far more relevant set of metrics.
Old Jul 14, 2019 | 02:48 PM
  #32
enderle's Avatar
I did the tube change on my XKR while I still had it. It did increase the SC whine a lot but I didn't see much if anything on the dyno. I did get infrequent leaks and it was a real headache when it came to getting the car smog certified. Decided the aggravation wasn't worth it and wouldn't do it again for whatever that's worth.
Old Jul 15, 2019 | 12:15 AM
  #33
would wrapping the tubes in the gold heat wrap foil reflect the heat for the better? like this
Old Jul 15, 2019 | 07:46 AM
  #34
Tel's Avatar
Tel
FWIW - I will monitor IAT 2 temps with OEM and with pipework, once brackets are sorted out.
Old Jul 15, 2019 | 01:08 PM
  #35
T-Mack's Avatar
Temperatures are not that important when we have IC. Although it is true that if we want to gain power, those who already have a flash will be those who will get more hp, with IC is more important Quantity than the quality of the air (cold).
Old Jul 15, 2019 | 09:18 PM
  #36
domino_z's Avatar
pretty cheap if it does add some sc whine
i'd just wrinkle black spray it myself as the alu polish look is a bit too ricer for this 30 yr old
Old Jul 18, 2019 | 08:47 PM
  #37
Unhingd's Avatar
Default Guess what I’ll be doing tomorrow morning
Old Jul 18, 2019 | 09:30 PM
  #38
OzXFR's Avatar
Great!
Blow by blow running commentary and pics would be much appreciated!
Old Jul 18, 2019 | 10:02 PM
  #39
Unhingd's Avatar
Great!
Will do.
Old Jul 19, 2019 | 02:29 AM
  #40
planet_FType's Avatar
Question Not sure
These comments may not be relevant regarding intake kits for the F-Type, but I always like to see calibrated before/after BHP figures before I spend. My previous ride - a Mercedes A45 AMG producing 400+ BHP - had many aftermarket intake kits available. Then someone went on a dyno and removed all pipes, filters, so it was just a large hole before the turbo. There was absolutely no increase in power. Just sayin'.
