Misfire Cylinder 5 and 2
Old Mar 17, 2025 | 10:21 AM
Crustacean99's Avatar
Default Misfire Cylinder 5 and 2
Hello Again,
Back in October I had a misifire while running low on gas, I had the vehicle towed to a Jaguar dealership, where they said due to corrosion on the fuel rail bolts, that an engine was needed.
I towed it to a different mechanic and they put the car back together and it ran fine for about 1000miles until it started misfiring again on 5 and 2, no smell of fuel in the oil and no smoke. There is a circuit level low code on #5 injector and a CANbus A fault in the PCM
In addition to the misfire, I’m getting water ingress to the trunk area which is what I suspect to be the actual cause of the fault.
The misfire occurred while driving through a rainstorm and immediately after hitting a puddle on the highway.
KylefromBahamas
Sep 23, 2024 10:53 PM
dbritt320
Apr 22, 2023 01:04 PM
NYCJAG2006
May 16, 2022 04:34 PM
lmerritt
Mar 4, 2014 02:37 AM
dennisw
Aug 5, 2013 01:34 PM
