Need help with a problem
Old Nov 27, 2021 | 12:47 PM
Paul champagne's Avatar
Default Need help with a problem
Hello all,
I just completed a 3000 mile trip, with nothing but enjoyment. The car was perfect.
But... After a night of heavy rain, this morning, the car starts and runs fine, but I don't have radio or maps. All controls for the car itself run fine from the screen but nothing for audio or directions.
I assume water got in somewhere and shorted something. It happened before, a few years ago and it actually fixed itself before I could find the source of the problem, which I would prefer to find this time.
Anyone can point me in the right direction for diagnosis?
Thanks in advance
Old Nov 27, 2021 | 04:08 PM
lizzardo's Avatar
I'm not sure what module or connector might be the problem, but I recently discovered water in the back. I was traveling while we had a deluge here: 8" of rain in 24 hours. When I returned home I noticed some condensation on the inside of the windshield. When I checked I found some water in the place where the battery lives. Not very much, but more than the correct amount of zero
I dried everything out and seem to have avoided any issues, but I was not able to find the leak with the garden hose. I'll probably need to pull all the trim out of the back, and maybe get out the pressure washer.
Anyway, that's the preamble to my advice to check that rear area.
Old Nov 27, 2021 | 05:36 PM
Will do thanks. The fact that only the antenna related stuff is affected is also strange.
Old Nov 28, 2021 | 09:02 PM
lizzardo's Avatar
I did have an antenna failure that was fixed under warranty. It only affected satellite radio but it is an amplified antenna so when it failed, I would get messages that it was trying to acquire signal.
Old Nov 29, 2021 | 12:37 PM
I have found no leaks anywhere so far. All the fuses appear to be in excellent shape.
Everything works, except the audio/video and the directions/guidance.
I will undo the ground and reset the system to see if that helps.
RicardP2010XKPortfolio
Aug 12, 2021 06:57 AM
X2 Jag
Oct 29, 2019 11:30 AM
pab
Dec 18, 2012 08:41 AM
chazaroo
Nov 11, 2012 12:19 PM
loulizjag
Mar 16, 2012 06:06 PM
