Negative camber on F-Type V6
Hi guys,
As I have mentioned in a number of other posts regarding other things, I am currently (amidst the covid-pandemic) trying to plan some track mods to my newly imported base V6 manual.
Now to a tricky question: Negative camber on front and rear axle.
On my previous track car I had ~3.5 degrees negative camber in the front and ~2.5 degrees negative camber in the rear in order to improve cornering, and for that car (a BMW 130i) it was perfect. Now, how can I adjust the camber angle on the F-Type? What modifications do I need to do in order to allow for at least 2 degrees in the front and 1 degree in the rear?
Thanks a lot!
/Jonas
Thanks a lot!
/Jonas
Hi guys,
Thanks a lot!
/Jonas
Thanks a lot!
/Jonas
Good luck!
DC
Negative rear camber can be dialed in by installing the appropriate lowering springs. There is adequate adjustment on the front to dial in whatever you want.
Ah, I see, that is great to hear! So basically I should be able to get a good track-focused wheel alignment without any other aftermarket suspension components except for lowering springs?
Here is some light reading for you. All info about alignments on these cars. I know there are a few limitations on adjustments with these cars. Especially with AWD models. But you should be able to glean plenty of info to start with the attached document.
Good luck!
DC
Good luck!
DC
DC
