No Symposer On 2021 F Type R ?
Old Aug 15, 2021 | 05:02 PM
Dwight Frye's Avatar
Default No Symposer On 2021 F Type R ?
I thought I should start a new thread rather than piggyback on one that started 5 years ago. I had read the tutorial that Lizzardo posted about defeating the Symposer by plugging the outlet pipe where it met the outlet adapter. I finally got around to popping the hood on my 2021 F Type R this morning. The top photo is Lizzardo's, the bottom is mine. Photo of mine taken with the firewall towards the right.
Unless I am not seeing something obvious, there is no fitting and hose leading to the firewall on my car. So Jaguar must have deleted the Symposer in the last model year or two ?
One less thing to worry about.
Old Aug 15, 2021 | 06:22 PM
lizzardo's Avatar
If there is one, it's been tucked under that cover for a cleaner look. That black cover cover has hinges on the valve cover side. Unclip the firewall side, flip the cover up and get another picture.
Old Aug 15, 2021 | 06:55 PM
Here is another pic with the plastic cover flipped up and back. I think the only hose that goes to the firewall is for the air conditioner.
Old Aug 15, 2021 | 07:02 PM
lizzardo's Avatar
I don't see it. I wonder if that was for all models of that year or just some, and what year that happened. I find it to be obnoxious dead weight, so good riddance.
Old Aug 16, 2021 | 07:48 AM
Therock88's Avatar
Yes...looks like you DO NOT have one. Congrats From your photos, there is no main body, or the tube that would connect to the diaphragm at the firewall.
DC
Mine with Symposer removed...looks like yours.
Old Aug 16, 2021 | 08:29 AM
From looking at the schematic of the Symposer there sure was a lot of parts involved just to funnel some noise into the cockpit. I'm glad that the factory decided not to install it on my car.
Before I looked for it I took a drive and tried to listen for the sound coming through behind the dashboard. But each time I accelerated hard with the active exhaust open, the sudden increase in noise right about 3500 RPM seemed to be coming from directly outside the driver's door and under the car. I have not seen a diagram of the exhaust system but I assume there is a muffler or some component right there.
Also when I accelerate hard and back off the throttle while in the manual shift mode, the loud bangs and pops also emanate from the same spot. The first time I made that happen it startled me a little since the sound was so close, I guess I was expecting it to be coming more from the exhaust tips.
Perhaps some owners of 2020 and 2021 F Type R's will chime in and let us know if their cars have that contraption or not.
Old Aug 16, 2021 | 10:00 AM
Therock88's Avatar
Here you go...
Old Aug 16, 2021 | 10:03 AM
clubairth1's Avatar
Community Influencer
Good to know. I would love to see exactly how Jaguar did it so the rest of us could do it too!
Old Aug 16, 2021 | 11:27 AM
Cluck's Avatar
Just took a look at my MY21 P450 and the rear end of the V8 looks like this.
EDIT: If you need any other photos, let me know. I might even remember to remove the cover before I take them!
Old Aug 17, 2021 | 09:10 AM
Thanks for the diagram Therock88. The sound seems to be coming from the X junction, or around parts # 30.1.01 and 30.10.02. Where are the valves located ?
Cluck, it appears that the 2021 P450 version also has dispensed with the Symposer.
Old Aug 17, 2021 | 09:19 AM
Therock88's Avatar
Sure thing....Valve is in red circle. Only one pictured, but they are on both sides.
DC
wouldbeowner
29
Sep 30, 2020 04:58 PM
arnold6324
Feb 13, 2020 11:58 PM
wouldbeowner
Aug 28, 2019 01:14 AM
IMMD
Dec 30, 2016 11:41 AM
PinnacleWax
E type ( XK-E )
Jan 29, 2015 02:38 PM
