Noise When Turning Left
Old Dec 23, 2023 | 02:14 PM
mayson's Avatar
Default Noise When Turning Left
My car makes noise at the front left wheel when turning left only (video site below); I'm not sure if it is a bad CV joint, bad wheel bearing, suspension, or steering issue.Any help or experience with this is greatly appreciated. Thanks in advance!
(video site) https://sites.google.com/asu.edu/may...ome?authuser=2
Current info:
- Mileage: 54K
- New front tires: less than 1K miles on them
- Front brake pads: inspected yesterday and currently between 3–4 mm (the noise is not produced when applying brakes regardless of the amount of pedal pressure or decelerating speed)
Maybe it is a brake pad issue, which I will change after the new year, but I was curious if anyone out there is able to detect something else more specific. Thanks again.
Old Dec 23, 2023 | 03:42 PM
scm's Avatar
scm
The slow left turn sounds a little like the one I had a while ago which turned out to be the Torx bolts holding the brake shield in place which had unscrewed and the heads were contacting the disk. My independent Loctitened 'em up and it's been fine ever since.
Good luck in tracking it down!
sanchez
Jun 13, 2022 08:31 PM
TBanks98
Oct 2, 2021 05:05 AM
mark campbell
Oct 17, 2017 06:37 AM
robinakirk
Jul 2, 2010 01:10 AM
julio pena
Jun 17, 2009 09:37 PM
