O2 sensor error
Old Apr 22, 2023 | 03:23 PM
BritCars's Avatar
Default O2 sensor error
Hi - got a check engine light on my 2017 F Type SVR yesterday. Pulled the codes - P2276. O2 sensor signal stuck lean bank 2 sensor 3
I know these O2 sensors fail and thought there was an extended coverage (here in USA) for 8 years or 80k miles or something like that? I asked my dealer this morning and they said that's the case on some vehicles but not on mine
Seems odd given it's a common issue. Anyone know the specifics? I thought there was a letter or bulletin from JLR about it a while back
If not covered, how easy to replace? Is it just an unbolt from the exhaust system and where is that specific sensor located? Issue of course is car is so low to ground that it will be hard to access without a lift...
Old Apr 22, 2023 | 09:09 PM
OzXFR's Avatar
See this post for the extended warranty details: https://www.jaguarforums.com/forum/f...0/#post2491387
Old Apr 22, 2023 | 09:30 PM
BritCars's Avatar
Thanks Oz. V helpful. That suggests that my vehicle is covered as I had thought. I'll check again with dealer
Old Apr 22, 2023 | 11:44 PM
OzXFR's Avatar
The extended warranty pdf says the 2014 - 2017 F-Type is covered with no exclusion for model or type so I can't see how they can wriggle out of coverage on a 2017 SVR.
Give 'em hell!
Old Aug 23, 2025 | 01:22 AM
RobMar's Avatar
8 year warranty in Canada anyway. So I had them install the new one. Did have a chance to see the CAT after removal and some cells do look to have failed. About $2500 USD to replace with new unit including labor when it was all said and done.
Old Aug 23, 2025 | 11:14 AM
SS4PK's Avatar
Yeah, I'm still waiting (not really) on my money back from jaguar after 5 years on an O2 sensor. It's not going to happen, they will blow you off.
Old Aug 23, 2025 | 12:53 PM
colormegone's Avatar
I just had my 2018 F type R in for cat replacement and I was told that the O2 sensors are covered for 8 years 80,000 miles from the in service date. I have replaced my own O2 sensors, because for me, it is more of a PIA to take the car to the dealer than to change a $100.00 O2 sensor. My vehicle has had four of the six sensors changed so far and the right side cat in 36k miles.
Old Aug 23, 2025 | 01:17 PM
sov211's Avatar
not 8 years in Canada…10 years and 15 years depending on engine.
Old Aug 23, 2025 | 01:41 PM
No, I did not get a chance to look at the Cat.
Old Aug 23, 2025 | 02:58 PM
Dionysus's Avatar
Originally Posted by colormegone
I have replaced my own O2 sensors, because for me, it is more of a PIA to take the car to the dealer than to change a $100.00 O2 sensor. .
Same with me. When I brought mine in with a CEL (in 2019), that pointed to the bank 1 3rd O2 sensor, they cleared the code and told me to drive it more that there were reports of bad gas in the area. When the CEL came back a few weeks later I just went to Rock Auto, bought one of the non-OEM O2 sensors, installed it myself, about 30 minutes, it never came back. A year later, same issue in the Bank 2 side, did the same both have been fine now since 2019.
Dealers act like they're paying for these out of their pocket. They should be happy to change it as they should get paid for the part and labor. Jaguar must put them through hell to claim so it must be easier for the dealer to put off the customer.
SteveHall
Aug 27, 2025 12:04 PM
TM1238
Apr 28, 2021 08:19 AM
MattArnold
Apr 9, 2020 07:33 PM
UltraPeepi
Feb 2, 2020 04:24 PM
WaltB
Jul 8, 2014 03:55 PM
