OBD Reader Disconnect
Old Jan 18, 2022 | 03:00 PM
WCats's Avatar
Default OBD Reader Disconnect
So I had the OBD reader battery drain issue - thanks to the forum I knew what to do and got it resolved. But one thing I have not found here is the correct procedure for disconnecting the OBD reader so it does not cause the problem. Since it was the dealer that caused the problem and I am taking it in for service this week I want to - gently - remind them of the issue. I am sure they will be very appreciative.
Old Jan 18, 2022 | 04:52 PM
Therock88's Avatar
They need to "Close" the session before disconnecting.
DC
Old Jan 19, 2022 | 05:13 PM
WCats's Avatar
Thanks, I assumed it would be something simple.
I also assumed the dealer would know what he was doing.
Old Jan 20, 2022 | 07:53 AM
Therock88's Avatar
Yeah. You would think!!?? If my Dumb @ss can figure that out....They should be able to, with their Tech Training
DC
Old Jan 24, 2022 | 07:53 AM
chasers03's Avatar
DC can you describe in detail steps how to "close" the OBD session before disconnecting???
Old Jan 24, 2022 | 08:40 AM
Therock88's Avatar
Sure. I am specifically referring to the SDD - JLR Software I use (and dealers).
Screenshot:
DC
Old Jan 24, 2022 | 10:15 AM
chasers03's Avatar
Thanks DC however I thought we were talking about typical OBD Reader Disconnects not JLR dealer software and how to close their SDD JLR diagnostics. I am looking for the holy grail I guess of how to make a typical owner OBDII reader to close properly. Some do on their own and some don't it appears but the user has no part in the process....
Old Jan 24, 2022 | 10:57 AM
Therock88's Avatar
You are correct. Some will create no issues and some will...Not based on user input. I created a quick battery disconnect setup, and if I am ever uncertain, I just reset it...and then re-calibrate the hatch and windows...3 minutes.
DC
Old Jan 24, 2022 | 11:56 AM
chasers03's Avatar
I installed your well documented disconnect [had to wrap it with zips] and it works great....Thanks. Hope I don't wear out my window motors:-).
My challenge is that I need to keep the Allstate dongle installed all the time I am driving [to get the Milewise discount] and it initiates the constant 2.5 amp battery drain, not from the device. This is no problem if I drive at least every other day especially since I installed the expensive Lithium AntiGravity battery.. It has a dead battery protection that will also protect me if I go on a vacation however I will just do your disconnect/reset and remove the Allstate dongle in this case. Our F-types are supposed to have this same built in battery protection, ie. Intelligent Power System Management [IPSM] [page 176 of our manual] but apparently the famous parasitic load once latched bypasses it in some way???
Today I am going to try finding the source of the parasitic load by using a heat sensing gun pointing it a various fuses in the 5 locations on the car.
Old Jan 24, 2022 | 12:11 PM
Therock88's Avatar
Good luck with your efforts!
DC
Old Jan 24, 2022 | 02:37 PM
Carbuff2's Avatar
MAYBE its time to change insurance companies?
SOME companies have featured Jaaaags...Couldn't find the commercial I remembered...
MisplacedPriorities
May 13, 2024 07:07 PM
vandenplas408
Apr 30, 2017 01:12 AM
curtizb
Mar 17, 2015 03:41 PM
