OEM Driveshaft weight
Old Aug 27, 2020 | 09:52 AM
J444G's Avatar
Default OEM Driveshaft weight
If anybody would be that helpful and find out or measure OEM driveshaft weight for RWD V6S (or V8) F-type, I would ask a shop for a possibility to manufacture custom one from carbon fibre for weight savings and smoothness.
I need a weight for the whole shaft (I guess 2-piece), including the middle joint-chasis support, because the custom one will be 1-piece and this support has to be removed.
Thanks!
Old Aug 27, 2020 | 07:35 PM
Unhingd's Avatar
Thanks!
Do you have a weight on the proposed carbon shaft?
Old Aug 28, 2020 | 05:21 AM
J444G's Avatar
Well thats a chicken-egg problem, I need the original part to estimate the CF weight and the project sustainbility. If it is a steel one there will be significant weight savings, but if it is an aluminium one then there is problably no need to do CF.
Old Aug 28, 2020 | 05:47 AM
J444G's Avatar
But to give you an estimate, on my previous GT86 CF shaft was reducing from 24 (OEM) to 12 lbs and on Mustangs it is said it goes from 38 to 23 lbs approx. Since the power of F-type is more in the mustang territory, I am assuming that the weight savings would be around 15-20 lbs mark, but take this with a grain of salt right now. Remember that it is a rotational mass, but yeah rotational with very small diameter.
Old Aug 28, 2020 | 11:14 AM
ss23's Avatar
There is lots of give in my driveshaft at the moment and its in need of replacing with the replacement arriving at the dealer by next week. If you can wait another week or so, I’ll try and measure the weight of the old unit once its out.
Would love to send it across to you as a donor unit but I’m probably around half the world away in Dubai
Old Aug 30, 2020 | 06:17 AM
J444G's Avatar
That would be great, no hurry! If you could also measure the lenght between both joints in the car that would be perfect! I mean if you imagine straight distance between the gearbox and the diff.
Old Aug 30, 2020 | 09:23 PM
lizzardo's Avatar
If you're wondering if it's steel versus aluminum, there's a simple bit of magic you can use. Magnets are magic, right?
Old Aug 31, 2020 | 08:30 AM
J444G's Avatar
Yes, or it will weight about 15 or 40 lbs
Old Aug 31, 2020 | 09:32 AM
lizzardo's Avatar
I could check with a magnet without removing the part. I don't think I could weigh it while it's installed ;^)
Old Aug 31, 2020 | 11:31 AM
scm's Avatar
scm
Easy, just weigh the car, then subtract the weight of the other parts.
Old Sep 1, 2020 | 10:26 AM
lizzardo's Avatar
What about the weight of all the french fries under the passenger seat?
(No, not my car. No food allowed. When I was a mechanic though, this was a source of aggravation.)
Old Sep 3, 2020 | 04:16 AM
ss23's Avatar
Haven't got my hands on the old driveshaft yet and won't do till early next week but the shipping weight of the new driveshaft was 10 kgs (22 lbs)
eglisau619
Mar 9, 2021 07:08 PM
Glovebox
Jun 11, 2020 01:00 PM
Bret_T
Jan 13, 2020 09:10 PM
Simran Singh Randhawa
Dec 6, 2016 06:47 PM
racerxf12004
Aug 5, 2013 09:16 PM
