Official Jaguar F-Type Picture Post Thread
Old May 8, 2020 | 11:11 AM
  #2981
enderle's Avatar
I personally like the look of the spoiler, won't get one myself because I also like the fact ours retracts, but I do think the spoiler blends well with the lines and look of the car. Then again I'm kind of a huge fan of mods anyway. I think people should make their cars uniquely there own and certainly live that credo. Anyway, my 6 cents is I like it.
Old May 8, 2020 | 12:07 PM
  #2982
F-Type-Type's Avatar
Originally Posted by Ftypelover
Very distracting addition to an otherwise beautifully proportioned vehicle. Maybe okay for a track day if removeable, but more befitting a ricer IMHO.
It's all a matter of taste.... However, the guys at Special Vehicle Operations clearly disagree with you since they made this very same deployable carbon wing standard equipment on the SVR
Old May 8, 2020 | 12:13 PM
  #2983
Thanks for the comments. Actually I erroneously called it a spoiler - but it isn't a spoiler, it's a wing (upside-down wing). Like the standard spoiler, it deploys (tilts) at 95kmh and moves back to the position on the first photo when the speed drops under 60kmh. Us in Europe can also choose to have it deployed at all times during driving and stillstand (I believe the US model has a cleaning position but cannot be permanently deployed while on the move?).
Old May 8, 2020 | 09:23 PM
  #2984
Unhingd's Avatar
I do believe it is a spoiler, just like all the other F-Type spoilers (coupe and Vert). The cross section does not appear to be an airfoil, but rather a consistent thickness fore to aft (just curved upward toward the rear).
Old May 8, 2020 | 11:45 PM
  #2985
BruceTheQuail's Avatar
I quite like it. Unlike virtually everyone else, I'n not a lover of the tail of the F Type. Hips maybe, tail no. The wing/spoiler takes my eye away from the protruding lip which is more prominent looking with the centre exhaust.
Old May 9, 2020 | 02:36 AM
  #2986
Talking
Its an inverted wing alright, with aerofoil cross-sectional shape, see attached photos and a screenshot from the 2017 MY brochure explaining the effect of the upside-down wing. According to the SVO guys, it brings a drag coefficient improvement of 7,5 % and a lift coefficient reduction of 45% ("stowed") and 2,5% and 15% (deployed) - see brochure screenshot. The F-type really needs all de improved aero on the rear end that it can get since the lift at the rear end at speed is so significant that an error signal from the wing actuator will cause the ECU to limit the speed of the vehicle to 215 km/h (133 mph)!!! Moreover, when opting for the wing delete on the SVR coupe the top speed is reduced from 200 mph to 185mph, which again shows that the wing is not just a decorative item.
My main reason for installing it was the significant reduction in the lift coefficient to get better grip at the rear end in fast curves and my well-calibrated popometer clearly detected a significant improvement :-) On top of that, I was positively surprised by the looks after the install, especially in real life on the road this wing gives the car a more exclusive presence.
Old May 9, 2020 | 04:12 PM
  #2987
FIRE550's Avatar
I've been 172 mph in my car with the stock deployable spoiler. No error message here!
Old May 10, 2020 | 01:34 AM
  #2988
I did not intent to say that exceeding133 mph will give an error message if you have the deployable spoiler and not the wing. Let me rephrase: The car is limited to 133 mph ONlLY if the ECU receives a signal from the spoiler actuator that the spoiler cannot be deployed. I assume that your spoiler was deployed and there was no spoiler deployment error message when you had your 172 mph fun so it all makes sense.
So much for spoiler deployment error.
Regarding having a wing or a spoiler: The SVR is limited to 185 mph when it has been fitted (buyer choice) from factory with the deployable spoiler instead of the ”standard” deployable wing (with the deployable wing fitted from factory the top speed of the SVR is 200 mph). I mentioned this to illustrate that the wing has a real effect and is not purely ornamental. I did not intend to say that the F-type cannot exceed 133 mph WO the wing.
Old May 10, 2020 | 05:23 AM
  #2989
scm's Avatar
scm
I didn't think you did say that - you clearly stated that the limit was only when the spoiler system was faulty.
Old May 10, 2020 | 10:52 AM
  #2990
FIRE550's Avatar
Haha - yea that happened! Emphasis on * that an error
Old May 10, 2020 | 01:32 PM
  #2991
?!? The point you ate trying to make being?
Old May 10, 2020 | 02:05 PM
  #2992
FIRE550's Avatar
Point is.
That member SCM is stating " you clearly stated that the limit was only when the spoiler system was faulty".
In which you did not, thus the reason I posted that I've been 172 mph in my car with the stock spoiler. When I quoted SCM I put your post in there and circled the part where you say it limits your speed to 133 mph, nothing about a faulty spoiler. So I laughed in his post because you never said that.
You did correct yourself in the post to me, all good! However then that member posted that, so I thought it was funny.
Get it now?
Old May 10, 2020 | 02:10 PM
  #2993
scm's Avatar
scm
Point is.
In which you did not ...
Ah, I see the bit you missed from the original post:
"... the lift at the rear end at speed is so significant that an error signal from the wing actuator will cause the ECU to limit the speed of the vehicle to 215 km/h (133 mph)"
Note the words "error signal from the wing actuator" clearly stating the system is faulty.
Old May 10, 2020 | 02:22 PM
  #2994
Alright, let's allow this threat to go back to its intended purpose of enjoying pictures of the fantastic F-type
Old May 10, 2020 | 03:50 PM
  #2995
FIRE550's Avatar
Listen guys I'm not trying to start any fuss. I took @F-Type-Type post as the car wouldn't exceed 133 mph with the stock spoiler. In which I have been over 170 in my car with the stock deployable spoiler. So if I took it wrong my deepest apologies, didn't mean to upset anybody.
Old May 10, 2020 | 03:56 PM
  #2996
FIRE550's Avatar
I'll be done on this petty matter now but I just want to point out one thing.
* Note that he says WILL CAUSE !
To me that means it is going to happen, not could happen.
Enough said - carry on!
Old May 10, 2020 | 05:39 PM
  #2997
scm's Avatar
scm
Agreed. If there's a fault in the wing actuator system.
Old May 10, 2020 | 05:55 PM
  #2998
FIRE550's Avatar
Old May 10, 2020 | 06:08 PM
  #2999
scm's Avatar
scm
I accept your apology.
Old May 10, 2020 | 06:10 PM
  #3000
FIRE550's Avatar
