oil changes
Old Nov 23, 2014 | 10:59 PM
boyracer's Avatar
Default oil changes
manual says every 12 months or 12,000 miles. sounds like a lot to me. did any of your dealers suggest doing an oil change after the breakin period at about 1200 to 1500 miles?
Old Nov 23, 2014 | 11:06 PM
shift's Avatar
unnecessary. some people still do it though. then again, I don't really follow breakin procedures in the first place. of course in harsh driving conditions it will be more frequent. but for normal driving, it's fine IMO.
Old Nov 24, 2014 | 12:37 AM
mshedden's Avatar
I would, just for peace of mind.
Might not be necessary, but won't do any harm, and inexpensive.
Old Nov 24, 2014 | 08:07 AM
plmmd's Avatar
I would think t depends if its a lease or purchase- Unlike the Audi add Im not keeping it nice for the next owner!
Old Nov 24, 2014 | 09:10 AM
93xjs6cyl's Avatar
I think it's just like the old saying "Pay now or pay later." These cars do hold more oil than others, but it pays to keep your oil clean. Just like some of the new vehicles that claim to go 100,000 miles before needing a tune up, or park plugs that last forever, ect..
Old Nov 24, 2014 | 10:03 AM
Mikey's Avatar
Oil changes of 10,000-15,000 miles have been pretty much standard across the market since the early 2000s. SWMBO's lowly Civic is 10K miles.
The oil change places still want you to do it at 3K miles (of course).
Old Nov 24, 2014 | 11:26 AM
undfeatable's Avatar
A little early is never a bad thing especially considering this engine is supercharged. For instance, my little 1.4l multiair turbo says 10k miles (full synthetic) are good, but through dyno testing, we found that around 6k the engine starts to pull timing since the valves are fluctuated using oil pressure and its not as fluid. Not exactly the same principle here, but just saying its never a bad Idea to replace it a couple thousand early, especially on a vehicle of this caliber.
Old Nov 24, 2014 | 01:00 PM
F-typical's Avatar
So basically an engine that uses oil is good, as in the process of keeping it topped up the oil in the sump stays fresher.
Old Nov 24, 2014 | 01:27 PM
zach05855's Avatar
Or do what I do and send a sample of oil out for testing, the oil change is based on oil quality of the additive package.
this is one of the best places to use. then you will know for sure if your oil needs replacing. Cost $ 25
Tests / Price List
Old Nov 25, 2014 | 10:40 AM
Mikey's Avatar
Not really. The contaminates remain behind in the sump.
Old Nov 25, 2014 | 11:27 AM
Are any vendors working on magnetic fuel plugs? Would be more piece of mind to catch any metal chippings on the plugs and just clean those off with the oil change.
Old Nov 25, 2014 | 12:04 PM
Mikey's Avatar
I assume you mean oil plugs. Metal chips either fall to the bottom and stay there or are trapped in the filter along with other solid debris. Many modern engines don't have drain plugs, the old oil is sucked out from the top.
The oil is chemically contaminated which renders it unsuitable, it's not just a matter of solids.
Old Nov 25, 2014 | 01:12 PM
F-typical's Avatar
Contaminants ought to remain in the filter.
Old Nov 25, 2014 | 01:23 PM
I do mean oil plugs thank you. And what's it worth to you to add another $30 plug that just protects you even more?
Old Nov 25, 2014 | 02:10 PM
93xjs6cyl's Avatar
Default Magnet for your oil filter.
They do make a magnet that wraps around your oil filter so they are universal. But , they aren't cheap and I'm not so sure how well they work. I've never bought one. I'm pretty sure you can buy on at Summit Racing or Jegs. Last time I saw one I think it was about $60.00.
Old Nov 26, 2014 | 01:56 PM
ldmack3's Avatar
In aircraft they are "chip detectors". They sort of work the same (magnetized) but also have electrical contacts that turn on a light when enough chips are picked up. But they really only give you an indication that something is going on, not protect you by removing the chips.
Old Nov 26, 2014 | 05:46 PM
bocatrip's Avatar
If I were an F Type owner, other than proper maintenance which is always important, I would be more concerned about warranty issues down the road. For the $150 fee to change the oil annually, you have eliminated one loophole for Jaguar to pursue in case of the that unlikely engine failure while under warranty.
Old Nov 26, 2014 | 07:23 PM
Road Racer's Avatar
What is the recommended oil? I have a 98 X308...
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
