Oil Level : unavailable
Old Jan 7, 2021 | 09:05 PM
Dagreeny1's Avatar
Default Oil Level : unavailable
Hi,
I have followed the guidance on the forum and drove car around then tried again to get a reading. It still displays “Unavailable “. It is a 2016 F-type that I have only put a few hundred miles on it since I bought it from a dealership.
I can’t believe that the oil level would be low and cause this. Could it be a sensor or something else?
Any advice would be appreciated.
Thanks!
Old Jan 7, 2021 | 09:24 PM
DJS's Avatar
DJS
You have to wait at least 10 minutes after turning the engine off.
Old Jan 7, 2021 | 11:33 PM
PatentlawTX's Avatar
The above suggestion is correct.
Old Jan 8, 2021 | 01:07 AM
scm's Avatar
scm
Unavailable doesn't mean the level is low, it means the reading er, unavailable. As others have said, wait 10 minutes after turning the engine off. Or check it first thing in the morning before you start. Oh, and make sure the car is on dead level ground or the reading will be inaccurate.
Old Jan 8, 2021 | 01:50 AM
malbec's Avatar
You don’t have to wait.
Open the bonnet.
Select oil level.
Push Cancel twice in succession.
Old Jan 8, 2021 | 03:36 PM
sov211's Avatar
Or, much, much simpler....check it in the morning before starting the engine. The "10 minute" interval is to allow the circulating oil to drain back into the sump. Checking it after an overnight rest does exactly the same thing, except that you will feel neither frustrated nor mystified.
Old Jan 8, 2021 | 05:23 PM
Dagreeny1's Avatar
Default Thanks!
Thanks for all the responses! I left it overnight and it worked fine the next day.
Wink5
Sep 7, 2020 12:26 AM
Jssaab
Mar 3, 2020 10:26 AM
Brock
May 23, 2019 08:52 PM
mghirsch
Oct 17, 2017 07:07 PM
tom-r
Jan 11, 2017 03:22 PM
