I took my car in today to a place that I am having do a clear wrap. The installer immediately looked at the top of the rockers (between the panels) near the rear wheel and showed how the paint is chipped in this area. For my car this is on the passenger side, not the driver side. He said that every F-Type he has seen has chipped paint in this area.
On my car it's about 1/8", but he said some cars have been as long as an inch. Also, this is something that has gone through all layers of paint down to the panel itself.
This is not something that would have been caused by a rock hitting it as it is BETWEEN the panels and there is no damage to the surrounding area. Has anyone else seen this on their car?
Other owners have documented this problem, dealer should fix (repaint). Don't know if the problem re-appears later - others with experience will chime in, I'm sure.
There is a recall on this for 2014 cars. The recall involves some rocker panel mounting parts. The issue generally only affects darker colored cars especially BRG and Indigo
Since it's not safety-related, it's not a recall, but there is a TSB, and it will be repaired free of charge. The fix includes a protective backing to keep painted areas from rubbing together.
According to multiple sources here, cars built near the end of the '14MY and all subsequent builds have the protective backing. I've haven't seen any instances of '15 owners reporting this problem.
To the contrary, I have seen numerous 2015 owners remark of the same problem with their cars. So if the factory thinks they fixed this, they are mistaken.
Welcome to the club. Mine was delivered that way, they fixed it and it occurred in the same spot the following year. They fixed it again, but don't know if they did anything more than just repaint it.
Where on the rocker panel is that? The panel gap looks huge...
