Paint Protection
Old Dec 22, 2014 | 06:53 PM
Dremorg's Avatar
Default Paint Protection
Looking for a good shop in the NY tri-state area that can apply
Opti Coat or Ceramic Pro. Anyone?
Old Dec 22, 2014 | 09:37 PM
MI-FType's Avatar
Dremorg... Opti Coat is available on Auto Geek for $39.99 along with several other sealants including Pinnacle Black Diamond. All are very easy to apply if you follow the directions carefully. There are videos on You Tube to use as an aid. I have seen on this forum people are paying $1000 to get these sealants applied. That's crazy when you can do it yourself in less than hour. Save your money. I did, and got great results.
Old Dec 23, 2014 | 05:46 AM
Dremorg's Avatar
I was contemplating doing it myself but didn't want to screw it up. I'm pretty good at following direction so I'm going to take your advice & try it. Thanks MI-FType. I'll post pics before & after.
Old Dec 23, 2014 | 08:24 AM
MI-FType's Avatar
My pleasure Dremorg. It's pretty hard to screw up. Know that when you are putting it on it just takes a real thin coat and dissipates into the finish quickly. You will think it's not working and be tempted you to lay it on thicker, but there is no need. A little goes a long way. Any spots that remain "wet" looking after a couple minutes should be buffed with microfiber towel... and you are good to go! Very easy! I look forward to seeing the pics.
Old Dec 23, 2014 | 09:06 AM
Dremorg's Avatar
Which product do you think is best?
Old Dec 23, 2014 | 09:24 AM
jns2001's Avatar
The problem with the sealants is the preparation of the clear coat before you apply it. Every car even brand new come with little scratches, and you need to get rid of them all before you apply the sealant. Like someone said it is easy to apply it, but to prepare the clear coat, this is a whole new level of effort. Just my 0.02 cents. BTW I am using Opticoat and it is really a great product.
Old Dec 23, 2014 | 09:35 AM
Dremorg's Avatar
Agreed. I'm going to get it professionally detailed first to get rid of all the fine scratches before I use the sealant.
Old Dec 23, 2014 | 09:52 AM
Lovemonet's Avatar
A large part of having the sealant professionally applied, I would think, is the warranty. Do you receive a warranty if you purchase the product and apply it yourself? I am always a little leary of purchasing these types of items on eBay as they may be knock-offs and not the real thing.
Old Dec 23, 2014 | 09:56 AM
Foosh's Avatar
I can't imagine what a warranty claim on a paint protection product would be unless your finish starts developing "leopard spots" or something.
Old Dec 23, 2014 | 10:15 AM
StealthPilot's Avatar
The warranty will cover reapplication if it wears off. But it won't cover scratches which is the real reason you would need reapplication.
So warranty isn't worth anything in my opinion.
Old Dec 23, 2014 | 10:16 AM
Looking for a good shop in the NY tri-state area that can apply Opti Coat or Ceramic Pro. Anyone?
I would suggest Detailers Domain.
Old Dec 23, 2014 | 10:18 AM
Foosh's Avatar
How would you know if it wears off?
Old Dec 23, 2014 | 10:51 AM
ftypeguy's Avatar
Default dead pedal cover
Does anyone know whee I can purchase the dead pedal cove that matches the sport pedal covers? I would like a place that offers a discount if anyone knows?
Old Dec 23, 2014 | 11:09 AM
It's obvious. The hydrophobic properties of these coatings are striking.
Old Dec 23, 2014 | 11:13 AM
Gtechniq EXO V2 coating applied with 2 coats. Also XPEL Ultimate film underneath the coating. Photos didn't come out well with low light in garage so will post another time. It's quite glossy for white.
Old Dec 26, 2014 | 11:52 AM
Unhingd's Avatar
Keep in mind, the Opti-Coat will require the entire vehicle to be clay-bared to ensure removal of swirls and scratches in the clear coat. You also need to apply it in a clean-room, as any particulates in the air will stick to the surface during application and will remain visible. I have neither the patience nor the clean room and will be opting to have a professional apply the protection.
Old Dec 26, 2014 | 06:25 PM
PinnacleWax's Avatar
Former Sponsor
Here's one of my write ups for the Pinnacle Black Label Surface Coating - Literally the easiest coating you could possibly work with. Check it out:
Mustang vs Pinnacle Black Label Surface Coating - Auto Geek Online Auto Detailing Forum
Old Dec 26, 2014 | 06:59 PM
Foosh's Avatar
I really appreciate your write-up, and I'm sure your products can yield fabulous results. However, I wonder after purchasing all of the equipment and other products required, plus the amount of time involved (time is money for most of us); whether it's not just best to take it to a professional who already has the necessary tools and knowledge.
Old Dec 26, 2014 | 07:02 PM
Unhingd's Avatar
.... I wonder after purchasing all of the equipment and other products required, plus the amount of time involved...whether it's not just best to take it to a professional who already has the necessary tools and knowledge.
My thoughts exactly.
Old Dec 26, 2014 | 07:22 PM
Lovemonet's Avatar
I paid a professional to put the coating on my car but then purchased the Pinnacle Black Label products to maintain it. They work with any coating and produce great results.
