Part of roof mechanism not laying flat when top is down
Old Jul 27, 2013 | 01:37 PM
tai4de2's Avatar
Default Part of roof mechanism not laying flat when top is down
I'm not sure if my F-Type has always been like this or if it just happened, but I just noticed it...
There's a piece of the roof mechanism not laying flat when the top is down. It's one of the covers of the well into which the top recedes. I am concerned that something is stuck in there, or that maybe the part itself is going to get deformed if it stays like this.
I'm going to bring it to the dealer today but I'm wondering if anyone has any insight into this.
Attached Thumbnails Part of roof mechanism not laying flat when top is down-wp_20130727_005.jpg   Part of roof mechanism not laying flat when top is down-wp_20130727_004.jpg
Old Jul 27, 2013 | 07:16 PM
Jmrscuderia's Avatar
Please let us know what the dealer finds, I will keep and eye on mine.
Old Jul 27, 2013 | 09:54 PM
StuM's Avatar
Default Roof
Hope your problem is simple to address and your dealer is quick and capable. At least one other new owner has a running story line of major, repeat top problems on another F forum. Does not sound like the same thing you are experiencing, though.
Good luck.
Old Jul 28, 2013 | 10:57 AM
tai4de2's Avatar
On Saturdays they only have Range Rover guys available in the service department, so it will get looked at early this coming week.
Interestingly, another F-Type on the dealer's lot *seems* to manifest a very slight version of the same issue. I might just be seeing things now...
I'll report back once I have any answers or info.
Old Aug 4, 2013 | 01:09 PM
tai4de2's Avatar
The dealer adjusted this a little and it's maybe 30% better. They need to talk to Jaguar to get any further.
I suppose this kind of thing is to be expected on one of the first production runs of a completely new model. It's not impacting my driving experience or ability to put the top up and down so I'm not all that bothered.
Old Jul 15, 2015 | 04:28 PM
POCCNR's Avatar
Hello!
I am the happy owner of Jaguar FType S from 03.2013, so one of the first version. I just bought it in germany and brought it back in my country, Switzerland.
After few weeks I am experiencing the same type of issue:
- the plastic cover did not lay down correctly
- I pushed it down manually, it made a "clac" noise
- When I opened up the roof after, it made again strange "clac" noise
- Now when I open or close the roof, sometimes, I would say most of time, it makes stranges noise, a little bit worrying!
So I will bring it to the dealer (hoppefully there is the guaranty) for checking, I hope the whole mechanism does need to be changed...
By the way tai4de2, was your problem completely solved then?!
Old Jul 15, 2015 | 05:18 PM
POCCNR's Avatar
I found out part of the issue:
I compared the two sides and I saw the "faulty" right side has a problem with the setting: the flap is not going up enough, it misses something like 2 cms and so the mechanism is touching hardly the plastic flap each it goes down or up...
The good news is that I can pull it up to the last 2 cm manually so that everthing is moving smoothly, anyway I need to go the repair shop for recovering the orginal setting...
maybe I did wrong somethings the first time when I put down the plastic part manually...
Not easy to see on the picture... If you compare left and right plastic part you can see the mechanism schatches the plastic on one side...
SD96XJ6L
Jan 12, 2022 04:30 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
