Passenger compartment fuse box
Old Oct 10, 2019 | 11:38 AM
scm's Avatar
scm
Default Passenger compartment fuse box
My manual says to access the fuses in the passenger compartment fuse box "Unclip the access panel on the left side A pillar." Anyone able to point me to the access panel, I can see nothing obvious on the A pillar.
TIA
Old Oct 10, 2019 | 04:15 PM
Unhingd's Avatar
TIA
I thought the passenger side fuse box was under the floor.
EDIT: Never mind! Different side.
Old Oct 10, 2019 | 06:22 PM
RacerX's Avatar
Banned
There is a fuze box under the passengers feet.
Old Oct 10, 2019 | 08:15 PM
OzXFR's Avatar
The page/diagram in the Owner Handbook (attached) is a little confusing as it shows a LHD car (and mine is RHD) and two "passenger compartment" fuse boxes, numbers 3 and 4, on opposite sides of the cabin.
From memory they are opposite to what is shown in the diagram on my RHD car, so number 3 is under the floor on the passenger (left) side and number 4 is under the driver's (RHS) A pillar.
File Type: pdf
Old Oct 10, 2019 | 11:47 PM
Unhingd's Avatar
Yes, on LHD cars. I suspect the fuse boxes are in the same location on all F-Types and therefore the floor fuse box is under the drivers feet on the RHD cars and the pillar box is on the passenger side.
Old Oct 11, 2019 | 02:57 AM
scm's Avatar
scm
Interesting, my manual shows only 4 locations, number 3 is missing. The one I'm after is number 4 on your diagram, on the left side A pillar, but I can't see any obvious access panel.
Old Oct 11, 2019 | 03:42 AM
OzXFR's Avatar
I just had a poke around in mine and it's on the LHS (passenger side) not the RHS.
It's behind a carpet covered panel under the left side of the glovebox (up against the side of the car), I shone a torch up in there and I could see relays and fuses.
I didn't pull the panel off but some gentle wiggling suggests to me it comes off without too much hassle.
Old Oct 11, 2019 | 07:00 AM
Itismejoshy's Avatar
OzXFR is correct, its under the kick panel/carpet on the pass side, been under there a few times.
Old Oct 11, 2019 | 10:35 AM
scm's Avatar
scm
Thanks for this info - I'll have a poke around when (if!) it stops raining.
Old Oct 11, 2019 | 06:50 PM
Unhingd's Avatar
For clarity on this forum, it’s necessary to specify left vs right side of car (or are the fuse boxes flipped side to side based on lhd v rhd?).
Old Oct 11, 2019 | 07:05 PM
OzXFR's Avatar
At first I thought they were flipped RHD vs LHD, but on my RHD the #4 fuse box is on the LHS which is the same side as shown in the Owner Handbook for a LHD car.
So put simply that fuse box is always on the LHS of the car no matter where the steering wheel is.
Old Oct 11, 2019 | 07:19 PM
Unhingd's Avatar
Thanks...that’s what I thought.
tigerwoods
Aug 13, 2020 03:47 PM
lenavarrete
XJ40 ( XJ81 )
Jul 20, 2018 11:33 PM
leep123
Aug 9, 2015 03:31 PM
thedeamon
Aug 31, 2014 08:58 AM
nairnman
Nov 10, 2010 05:03 AM
