Plastic Coolant Lines
Old Nov 29, 2020 | 09:01 AM
Rondog's Avatar
Default Plastic Coolant Lines
I am new owner this year of a 16 F-Type R V-8. I do all my own maintenance work, on all my vehicles. I keep reading on the Forum about the plastic coolant lines that are brittle and crack and leak. So with my car being almost 5 years old, I am thinking I should probably replace these lines before a problem occurs even though it only has 17,000 miles on it. So does any one have a list of all these plastic lines with part numbers and descriptions that should be replaced?? I figure a good winter project would be to replace the lines, hoses, and coolant while I'm at it.
Old Nov 29, 2020 | 11:39 AM
scm's Avatar
scm
The part numbers that have been posted in the past (not sure which engine they apply to, if not both the V6 and V8):
Connector tube AJ811997
Outlet pipe AJ813865
Outlet pipe o-ring (2) AJ811350
Engine coolant pipe AJ813917
Radiator coolant hose T2R7744
Engine coolant pipe C2Z28258
Heater outlet pipe, crossover pipe AJ814007
Thermostat kit C2Z19929
Old Nov 29, 2020 | 03:53 PM
Rondog's Avatar
Hopefully they are for the V-8! Thanks for your input.
Old Nov 29, 2020 | 05:31 PM
OzXFR's Avatar
Also the expansion tank overflow tube aka the "radiator header tank bleed hose".
Part # T2R5910, get it from Britcar for cheap see here: https://www.brit-car.co.uk/search.ph...t=&xPerPage=10
arctic_man
Jul 31, 2020 05:59 PM
jetjack
Jun 16, 2020 03:39 PM
Canaan David Khoury
Mar 20, 2020 12:22 PM
dolamyte
Apr 21, 2015 07:16 AM
Scottish Chap
Sep 15, 2011 04:00 AM
